Balance shaft removal how to?
What I have seen 3x so far is the oil pump failing for some reason with the stubby shaft. Not on my own car BTW. Perhaps the lack of proper support? I am not really sure, but the turned down shaft seems like a better solution. Why do the stubby shaft thing when you can just bring the shaft to a machine shop and have it put on a lathe for about $40? I was a little worried about taking out the shafts, but now that the car is running, I am very happy that I did. 9K shifting here I come
If they don't have a lathe, they're not a machine shop. Even if they do have a lathe, they may not be a machine shop.
I'm looking in my garage..... Yep, there's a lathe. Nope, I'm not a machine shop.
is there something else we could put in place of that screw on the bottom right corner of the pump case mine was stuck in there and i had to drill it out would it be ok to put a bolt in there instead of the factory screw i really dont want to have this problem again
mine came out looking like this
mine started to round off so i just stopped messing with it. I had a spare front cover so im not worried. I dont see why you could use a bolt insteat of a screw they'll be doing the same thing...
These were posted on dsmtuners but i cant find the thread anymore there are around 20 pages of balance shaft threads
shaft and pump case
cut off this part
turn the rest of the shaft like this
until it looks like this
shaft and pump case
cut off this part
i just found out that there are 2 types of stub shafts that come in the kits one has an oil groove like the stock shaft and the other doesnt... its recommend not to use the one without and that is what cause oil pump failures
