IGR7A-G vs BPR7EIX
The BPR7EIX is a higher performance iridium plug than the stock IGR7A-G. According to the manual, the IGR7A-G is supposedly an "8" heat range, so go figure.
For the money just switch to copper plugs. Yes they foul quicker, but they are definitely easier to gap and are cheaper if you change between heat ranges often.
Agreed, copper plugs are worth every penny. They're cheap and require you to change them more often but that's a good way of keeping up with maintenance. I use the BPR8ES (one step colder).
WTT[MidWest]: ETS Extreme with V2
g7igo7
May 16, 2016 09:31 PM
