5th gear grinding????
Old Oct 15, 2007 | 02:08 AM
chrsevx's Avatar
Originally Posted by ASE_Tech@TTP
don't shift fast into 5th ever
Why?
Old Oct 15, 2007 | 02:16 AM
EVOIXMR8916's Avatar
same here....tcase 1,2,3,5 gringing and was replaced, now 5th agian, but takes mitsu to long with warranty work but will have to get to it soon....tcase agian also i belive... wow so mad....
Old Oct 15, 2007 | 02:20 AM
Originally Posted by chrsevx
Why?
less wear on synchros....
Old Oct 15, 2007 | 02:41 AM
vboy425's Avatar
synchro
Old Oct 21, 2007 | 02:51 PM
k2boarder3187's Avatar
my 4th and 5th gear are grinding really bad and it is really pissing me off. i bought my car with 44,000 miles on it, now it has 46,000 miles and it came with an ACT clutch..not sure of which one but the clutch seems to be fine. ANYWAYS my question is what is a Ballpark cost of having the synchros and probably gears changed??
Old Oct 21, 2007 | 02:56 PM
alan678's Avatar
5th gear syncro grind here....the car had 47k miles before the issue cam up.....then a few hundred miles later i blew my LSD (unrelated, i was drag racing when this happened)
So needless to say i am sending both to TRE for a rebuild....
Old Oct 21, 2007 | 04:16 PM
mitdrx's Avatar
Fellas there is actually a tsb that was released for the 5th gear synchro. The dealer just replaced mine for free.
Old Oct 21, 2007 | 04:24 PM
so if i bring it to a dealer it will be covered? even out of warranty? excuse my ignorance but if there is a tsb is that the same thing as a "recall" and they will do it for free?
Old Oct 21, 2007 | 04:32 PM
mitdrx's Avatar
A tsb is different than a recall but i called the deal and i had one of their techs ride along. He agreed and they fixed it. I do have some warranty left but they did not hassle me.
Old Oct 21, 2007 | 04:38 PM
number 8's Avatar
Have you tried adjusting the clutch pedal?
Old Oct 21, 2007 | 04:41 PM
no...how do i do that? and would that really have something to do with shifting into just 4th and 5th gear and not the other gears?
Old Oct 21, 2007 | 04:50 PM
number 8's Avatar
Yes. If you do a search there's a how- to with pictures. Basically loosen a bolt at the top of the pedal and then turn the plastic clutch rod.
Old Oct 21, 2007 | 04:51 PM
mcwop23's Avatar
I've had a 5th gear grind since driving it off the lot, hasn't been a problem
Old Oct 21, 2007 | 05:00 PM
ran the search thanks...i guess ill give this a shot tomorrow..and if this doesnt help im thinkin synchros no?
Old Oct 21, 2007 | 05:16 PM
number 8's Avatar
Probably, but I wouldn't be suprised if you fix it with the adjustment.
