SWITZER TUNED EvoGreen, E85, 439HP/454TQ
Old Oct 17, 2007 | 04:56 AM
prostcj's Avatar
Originally Posted by EVOlutionary
Around 30 spike, falling to 22-23 or so by 8K. no other mods to the fuel system. We'll see how long it lasts until something corrodes!
EVOlutionary
I have yet to hear of any problems. The 15% gasoline seems to prevent corrosion.
Old Oct 17, 2007 | 07:20 AM
Soon2BEVO's Avatar
Originally Posted by Ducu
awesome numbers... im thinking to put fp evo green as well but i heard that oem con rods will fail...
That is compeltely false, whoever told you that is an idiot. I was running my Green at 30psi everyday with 75,000 miles on the car.
Old Oct 17, 2007 | 07:22 AM
Paul Nelson's Avatar
is it truth? with my mods (from sig) will it be safe just to put the turbo ad run at 30 psi???
now on my stock turbo im runing 24 psi peak going to 21psi to redline on the street and for drag 26 psi to 23 to redline.
any advice?
I ran a 35r and 500whp on my stock rods with about 200plus passes at the track. Has to do with the tune,rod bolts
Old Oct 17, 2007 | 07:32 AM
sblvro's Avatar
I thought BIG3ETR has two switzer tuned evo's too.
Old Oct 17, 2007 | 07:34 AM
Soon2BEVO's Avatar
EVOlutionary, I wouldnt rev that thing past 7500rpm, especially if boost is falling that low. My powerband was extremely similar and I found out that shifting at 7200-7300 was the best place. Anyplace after I would lose ground.
Old Oct 17, 2007 | 07:41 AM
Rez90's Avatar
that car must be a party
Old Oct 17, 2007 | 09:16 AM
9sec9's Avatar
Very nice dyno plot. Well done.
Old Oct 17, 2007 | 10:06 AM
JrCRXHF's Avatar
For running on the road or drag strip yeah i would agree to keep the motor in the power band
but for auto X he does not have time to get out of second gear and go for third so if u can rev a little higher at the end of a run you can pick up a little speed and cut some time off your run. instead of hitting the rev limit
Old Oct 17, 2007 | 10:07 AM
JrCRXHF's Avatar
I have been running it in my turbo CRX for 5-6 years now with just an upgraded pump and injectors and it has been fine.
Old Oct 17, 2007 | 10:17 AM
Soon2BEVO's Avatar
Yes I was referring to the drag strip.rc! Yeah I could see needing to hold out the revs longer, especially with our short gearing.
Old Oct 17, 2007 | 10:21 AM
Srt-4 Turbo 7's Avatar
nice, congrats!
Old Oct 17, 2007 | 10:28 AM
Links0000's Avatar
Awesome numbers
Old Oct 17, 2007 | 12:13 PM
Jeff_Jeske's Avatar
Very nice numbers... holy hell.
That might work well for an autocross but the EVO is a thirsty SOB during a lapping day. You'll be eating up an entire tank of fuel in a 20 minute session!!!
Old Oct 17, 2007 | 12:45 PM
mplspilot's Avatar
Originally Posted by xspsi4
I ran out of fuel on 1000cc's at 32 psi on a 20g so you may wan't to check you idc.
+1
I'm running out of fuel with one pump on 1000 and running leaner than i want with more taper than i want. Do you monitor afr's?
Old Oct 17, 2007 | 12:59 PM
JTB's Avatar
JTB
The numbers look good with great area under the curve!
I too am considering creating an E85 map with my green -- especially since they just put in a station near where I work
Have you had any drivability or cold/hot start problems?
