Could front drive axle be going bad?
Old Oct 17, 2007 | 08:57 PM
redevo21's Avatar
Well I was changing my oil this evening and was looking at my passenger side tire and notice that underneath the drive axle like where the rubber boot is that it was a little wet. Almost like oil was coming out. I felt the rubber boot all around and it felt dry and didnt feel any rips. Should I worry or no?
Old Oct 18, 2007 | 08:23 PM
JDMCT9MR's Avatar
Well if you see axle grease than you may have a problem but if not than you should be fine.
Old Oct 18, 2007 | 08:29 PM
evoracingstar's Avatar
so there is no little hole in ur boot at all ur saying wen u felt it? bc i just order a new axle seal. not the boot bc my boot was fine. if u can put it up in the air and look up where the axle seal is and if it is leaken from there u just have to replace the seal. its like 8 bucks. no biggie.
