What did I do wrong?
Old Oct 18, 2007 | 11:21 PM
SWOLN's Avatar
Okay, I changed out my injectors from stock to 750's. Loaded a new map, and the car started and ran fine. I needed to run some of the fuel out of the car so I drove it around for a while, everything was still fine, didn't boost because I'm supposed to get tuned tomorrow. Ran the fuel down enough to change out my fuel pump. Changed the fuel pump, and now the car will not start. I thought that maybe it could have been the fuel pump so I put the stock one back in, and it still doesn't start. Did I do something wrong? Is there a priming sequence I needed to go through?
Old Oct 19, 2007 | 12:11 AM
SWOLN's Avatar
after rereading my post I forgot to mention that, while installing the pump the black rubber end that sliides over the white plastic piece, on the end of the pump split. ...also I took the return line off,and there is no fuel coming out of the line when I turn it over.
Old Oct 19, 2007 | 12:17 AM
hksevoix's Avatar
make sure your pump is assembled properly, make sure all your lines are connected and give it a few tries to turn over
Old Oct 19, 2007 | 12:48 AM
RenEvoIX's Avatar
check the power supply maybe u ve a blown fuse..if not check if the pump turns on when u turn the ignition but dont start if u can hear the pump n still not getting fuel check if u connect the fuel lines properly maybe u connect the out line to the return..
Old Oct 19, 2007 | 02:38 AM
silex's Avatar
Before changing your pump, you want to be sure to pull the pump fuse and start the car and let it die. This lets all the fuel out of the system and de-pressurizes it.
Old Oct 19, 2007 | 03:25 AM
RyuEvoIX's Avatar
That black rubber end would be your fuel pump grommet. Without a properly seated and NON-damaged grommet your car will not hold fuel pressure and will not start. Get a new grommet.
Old Oct 19, 2007 | 11:59 AM
SWOLN's Avatar
Thank you for the assistance. I'm an idiot sometimes. The black grommet just sits on top of the white plastic piece, it does not get slid aroud it. I bought another one from Mitsubishi, and everything is better now. I think I'm going to just work on tricycles from now on.
