Cam question
Old Oct 19, 2007 | 04:01 PM
evoryne's Avatar
Cam question
Hi im planning on getting my 60k maintanence done soon so i thought i would throw in some cams while im at it. im thinking about HKS 272
My question is would i still gain a good amount of power with just a E-mail flash?
Also when i get them installed should i tell the mechanic to do the cam timing or can i just do it myself?
Thanks for the input
Old Oct 19, 2007 | 06:04 PM
dubbleugly01's Avatar
your mechanic should set the cam timing at 0/0. Unless you have adjustable gears, there won't really be any setting of the cam timing.
I'd recommend S1's from GSC. They're expecting the next batch in for the Evo 8 in 5 more days. They're such a good cam for your setup, it's hard to keep them on the shelf.
check this thread....
https://www.evolutionm.net/forums/sh...d.php?t=301991
and yes, you will get very good power results with these cams, especially in the mid range, even with mail in flash. Custom would be better, but a mail in will show significant gains.
Old Oct 19, 2007 | 07:56 PM
impreza2darksyd's Avatar
+1
Old Oct 20, 2007 | 04:01 PM
evoryne's Avatar
Im looking for more top end power i think im leaning towards the BC 272 ive heard some good stuff about them. Thanks for the info
Old Oct 20, 2007 | 05:34 PM
24hrs (to the minute) later, you changed your mind from HKS 272's to BC 272's.
What "good stuff" did you hear?
Old Oct 20, 2007 | 08:22 PM
evoryne's Avatar
haha thats a coincidence. The "good stuff" i heard was that they make as much power as the hks and they are alot cheaper too.
Old Oct 20, 2007 | 10:12 PM
wshihdnevo's Avatar
I also recommend gsc s1's, they are better than any HKS 272 IMHO. There are results here on the board.
