Largest cam on a stock ECU?
Old Oct 21, 2007 | 09:19 PM
MitsuJoe's Avatar
Alright I am curious who has pushed the bar the most in this arena. I am interested in knowing how well the car ran and the general details!
I am considering S2's on the stock ECU at this point....although JUN 272's could also be interesting.
Old Oct 21, 2007 | 09:25 PM
JohnBradley's Avatar
Realistically the Cossies are bigger than the S2's at least from the specs (ramp rates aside). There is at least one person on this board that I know of that has some Revolvers that "work" with the stock ECU. EvoDan2004 I believe is still running them.
Old Oct 22, 2007 | 05:51 AM
ONRAILS's Avatar
there have been revolvers on stock ecu. You'll be fine. The car will idle... lope like hell.. but run... thats what matters
Old Oct 22, 2007 | 10:05 AM
MitsuJoe's Avatar
I may also be considering Jun 272's any ideas with these?
Old Oct 22, 2007 | 10:35 AM
fimotorsports's Avatar
for what kind of turbo?
Old Oct 22, 2007 | 02:43 PM
MitsuJoe's Avatar
This is classified. Something with a T4 flange.
Old Oct 24, 2007 | 05:54 AM
ONRAILS's Avatar
If you convert to a ls1 maf you'll be perfectly fine dude.
think about the cams they do.
Old Oct 24, 2007 | 07:41 AM
MitsuJoe's Avatar
I have been considering ECU+ to utilize the GM MAF control....tell me more. I may go this route again!
Old Oct 24, 2007 | 09:29 AM
GregGSC's Avatar
from the posted spec's of cosworths 272s they are smaller than the S2 cams. less intake lift, and not as steep of of a flank rate.
S2's will work on the stock ecu its been done before.
Old Oct 24, 2007 | 09:41 AM
stig's_mentor's Avatar
u talkin about the cosworth m2's? if u are what are the spec's? as this is somethin that has been asked b4, but there was no answer
Old Oct 24, 2007 | 10:10 AM
Mad_SB's Avatar
MafTranslator (just the regular evo maf translator, not the maftpro) + gm maf = ~$250, can run blow through or draw through, Blow through will require ic piping mod. I've tuned (ecuflash) a few cars with this setup and it does seem to improve idle with big cams when you go to blow through mode. Never had a problem on the stock ecu with cams though, but I've never tried to tune anything larger than 280's.
TTP sells the translators IIRC.
Old Oct 24, 2007 | 11:44 AM
Sorry I was thinking the IX cams. @ .050 to @ .050 the Cosworths are advertised as being larger. They also seemed to be measured in the European method rather than what I am used to seeing because where the Cosworth cam card has valve events happening arent typical. I think this coupled with whatever the ramp rates are (I dont have the reverse engineered specs on my work computer) are why even though they claim 255/222 @ .050 Greg is saying they are smaller.
Old Oct 24, 2007 | 12:37 PM
TTP Engineering's Avatar
I have used:
HKS 272 272
HKS 280 280
GSC 280 280
Cosworth M2 for Evo 8
all on the stock ECU.
Old Oct 24, 2007 | 01:09 PM
RazorLab's Avatar
Originally Posted by TTP Engineering
I have used:
The M2's do indeed work fine on the stock Ecu. They lope like hell but the idle is pretty strong.
Old Oct 24, 2007 | 06:53 PM
CarbonKrazyEvo9's Avatar
cant wait to get my cams! I have seen many people use 280's on stock ecu
awdboosted
Oct 22, 2013 04:19 PM
mantosride
For Sale - Miscellaneous Automotive
12
May 25, 2010 02:04 PM
ski10804life
Jun 28, 2007 07:03 PM
stance
16
Nov 16, 2006 03:33 PM
djd24
Sep 8, 2006 06:05 AM
