Oil squirters
Old Oct 21, 2007 | 10:04 PM
ecuflasher's Avatar
Oil squirters
I just bought a set of new oil squirters to replace my old ones that I lost leaving it lying around in my garage. Now that I'm going to install them, is it necessary to test the check valve or can I trust that they will work since they are brand new? Also, is it necessary to put loctite on the threads before tightening them down to specs?
Old Oct 23, 2007 | 07:33 AM
ecuflasher's Avatar
bump
Old Oct 23, 2007 | 08:55 AM
PATRICK B.'s Avatar
I would assume you could trust them if they are indeed brand new.
When we put motors together we DO NOT use any sort of loctite.....just tq to 25ft/lbs.
Old Oct 23, 2007 | 09:21 AM
ecuflasher's Avatar
I'm going to put them in a stroker shortblock with no balancer shafts and using stiff engine mounts...will they be 'shaken' loose over time?
Old Oct 23, 2007 | 11:01 AM
PATRICK B.'s Avatar
GOD i sure hope not lol.
Mine is still 2.0L but we have done them on other stroked 1G/2G DSM's.
We almost always do a balance shaft removal and my car does have poly mounts and vibrates a bit but nothing crazy........i do think that the vibe maybe caused the oil filter to loosen up, drop pressure, and spin a balance shaft bearing Hence the built 2.0L.
Old Oct 24, 2007 | 07:03 AM
ecuflasher's Avatar
Thanks for the advice...just put them in today without using loctite
benIX
26
Feb 4, 2022 04:36 AM
nikush
Oct 4, 2015 02:39 PM
evoboy2006
20
Feb 16, 2014 05:55 PM
03black8gsr
13
Nov 18, 2012 06:30 PM
KOM88
Apr 12, 2007 10:25 AM
