Install ARP studs without head removal?
Old Oct 24, 2007 | 05:37 AM
trboboost91's Avatar
I am wondering who has had good luck with installing arp studs without removing
head and replacing headgasket? i know once the gasket is compressed it should not be uncompressed without replacing it. so are you guys replacing i stud at a time, torqing it and then moving to the next so the gasket does not become
decompressed? i don't want to get it there and attempt this and then a week leater have the headgasket take a dump because this didn't work.
putting cams in this weekend and want to knock this out at the same time.
any help appreciated.
Old Oct 24, 2007 | 07:14 AM
Pr3z's Avatar
You can try it. Some have gotten away with it while others have not.
Just be aware you may have to do a HG if it doesn't go right.
Old Oct 24, 2007 | 11:21 AM
cpoevo's Avatar
I have done it one at a time and had noe problems. My buddy did his one at a time and he runs a 50trim on race gas at about 30 psi and has had no problems.
Old Oct 24, 2007 | 11:27 AM
GTVEVO's Avatar
The statement posted above is as clear as it is going to get. As a personal recommendation I would do the job right the first time. Short cuts work sometimes and sometimes they just dont. Personally it didn't work for me so I pulled the head off and did it right.
Old Oct 29, 2007 | 07:09 PM
dancarroll0283's Avatar
Its like a 50-50 chance that it will work, and that it wont...... If you can, I'd pull the head, and do it the right way...... Cause if it doesn't work, your gonna have to pull it anyway.......
Old Oct 29, 2007 | 07:37 PM
Intell Design's Avatar
i just had my done 2 days ago and so far, so good. But if you have time, I would say do it the right way the first time.
Old Oct 29, 2007 | 07:42 PM
Lee2speed's Avatar
i had it done with a 50trim + meth daliy driven no problems yet.
Old Oct 29, 2007 | 09:31 PM
James Reese's Avatar
I would do it right the first time but doing one at a time following the torque specs and removal,install sequence is worth a shot. I have done many that way and havent had a problem.
James
Old Oct 29, 2007 | 09:37 PM
ottomatic's Avatar
My friend installed my cams and decided to install the studs too. He did that 1-by-1method and was successful. Take your time.
Old Nov 22, 2007 | 06:39 AM
itzcharlez's Avatar
my question is how do you know if your sucessfull or not?
i've been driving it for a couple months now and everything seems fine...
lol i did the one by one method cuase the shop that did it for me told me it was fine and they work on alot of evos.. him personally owning one..
Old Nov 22, 2007 | 06:53 AM
AWD Motorsports's Avatar
you would know if it was successful or not..if the car isnt over heating, your oil doesnt look like milk and your car isnt pushing water to the overflow i am sure its fine..
Old Nov 22, 2007 | 07:07 AM
itzcharlez's Avatar
lol what do you mean my oil looked like milk?
i've had it done a couple months now actually and done a few oil changes.. everything seemed fine to me..
never has my car overheated..
and i havnt checked the coolant overflow tank...
Old Nov 22, 2007 | 07:08 AM
if the coolant mixes with the oil it turns milky.. trust me you would know if you did an oil change.. i am sure you are fine..
Old Nov 22, 2007 | 08:56 AM
Hic's Avatar
Hic
I did it on 3 EVO's for gpN 2 years ago, and no problems at all. Just do it one at the time.
Old Nov 23, 2007 | 08:47 AM
CWiLL's Avatar
ive done 20+ headstuds installs and never had an issue i dont think theres anything wrong with it
