ARP bolts on Eagle rods
Old Oct 26, 2007 | 08:33 AM
ecuflasher's Avatar
Anyone know the torque and stretch specs of the ARP 2000 bolts that come with Eagle rods for the 4G63? I can't find the part number for them so unsure how much to stretch them by to get the correct preload.
Old Oct 26, 2007 | 11:01 AM
turbo speedy's Avatar
38 to 40 foot pounds
Old Oct 26, 2007 | 10:57 PM
Aby@MIL.SPEC's Avatar
^ double check with arp & be certain to use the correct lube for the torque reading, as using the moly lube under the head of the bolt will generate different values if you were to use just oil.
Old Oct 26, 2007 | 11:53 PM
EVOclub4's Avatar
hope this helps for you buddy ...luckily i just did mine a few weeks ago and i still got the paper for the specs....so here goes:
Torque Specs:
BOLT........................................IDENTIFICATION.........TORQUE.........BOLT STRETCH
7/16" ARP 8740..........................7/16" bolt head.............63 ft. lbs.......... .0059"-.0063"
7/16" ARP 2000..........................7/16" bolt head.............75 ft. lbs.......... .0064"-.0068"
7/16" ARP L-19...........................1/2" bolt head...............79 ft. lbs.......... .0073"-.0077"
3/8" ARP 2000............................7/16" bolt head.............43 ft. lbs.......... .0055"-.0059"
5/16" ARP 2000..........................3/8" bolt head...............28 ft. lbs.......... .0048"-.0052"
5/16" ARP Custom Age 625........3/8" bolt head...............32 ft. lbs.......... .0062"-.0066"
**To accurately determine the life of a bolt, it is recommended that a log of the bolts original free-standing (Untorqued) length should be kept and recorded upon sebsequent teardowns for inspection. The free-standing length should be checked against its original length. If there is an increase of .001" or more, or if there is any permanent deformation or galling, the bolt should be replaced.
this was all straight off from the installation instructions paper that came with it
Old Oct 27, 2007 | 09:24 AM
ecuflasher's Avatar
Thanks! This must be it Going to tighten them down using the stretch method.
Old Oct 27, 2007 | 01:38 PM
EVOclub4's Avatar
no problem
Old Dec 15, 2007 | 10:53 AM
TTP Engineering's Avatar
Yes 43ft-lbs with moly lube I believe.
And I just found those ARP 2000 bolts we were missing before I ordered you a new set Faisal. Just my luck. lol
Old Dec 15, 2007 | 11:58 AM
SeanC's Avatar
Usually, there is a maximum recommended torque. I would guess in this case, 43 lbs is the max.
If you cannot achieve the specified stretch within the maximum torque range, the bolts are not applying the necessary clamping force and are probably junk.
Old Jan 28, 2008 | 08:36 AM
boostGotMeLaid's Avatar
good deal
Old Jan 28, 2008 | 08:45 AM
doostinsmyth's Avatar
it is 45 ftlbs with arp moly lube....
My03evo
17
Jan 6, 2017 10:36 AM
mario's evo 9
13
Nov 20, 2014 09:05 AM
97dsm
Jun 6, 2013 10:05 AM
56Hotrod
20
Oct 24, 2006 03:38 PM
oj
Nov 12, 2005 09:04 PM
