Aluminum VS Carbonfiber Driveshaft
Old Oct 28, 2007 | 12:21 PM
GreddyEvo's Avatar
Originally Posted by Jasil
Your pushing current combination to the limit runn low 10's/high9's trying to squeeze a little more out of the current setup? If not it's not worth it at all.
I am not pushing my car to the limit, I was simply pointing out the power levels it is capable of handling. I find it to be worthwhile at some point, others will not. No big deal. My Evo is not my daily driver, but I am starting to run track days and this is one part that would provide a noticeable change. Think about the price some people spend on lightweight forged rims to reduce rotational weight, I see this as very similar. I am not trying to start anything, I just like the part.
Old Oct 28, 2007 | 02:05 PM
Jasil's Avatar
I like the part too there are just so many better bang/buck option that should be done first. It's like using the stock turbo and building the block first.
Old Oct 28, 2007 | 04:30 PM
unknown2's Avatar
Yes i know there are other mods i should do first. But, i run on the street alot so im looking into rotational weight loss. i can pick up an aluminum driveshaft for $537 thats why i wanted to know the + and the - for each. I think im going the aluminum route. Thanks for the replys everyone
Old Oct 28, 2007 | 04:40 PM
Erik@MIL.SPEC's Avatar
Where are you getting an aluminum driveshaft for $537?
Old Oct 28, 2007 | 04:47 PM
VRamirez2004's Avatar
You can get a carbon fiber driveshaft for 1200+ shipping from ACPT I think
Importimageonline.com sells them, I plan on gettin 1 for my chrsimas present well hopefully....
Old Oct 28, 2007 | 04:49 PM
h.funk's Avatar
I dont think its that important right now to get a cf drive shaft. If your pushing alot of hp and torque then maybe
Old Oct 28, 2007 | 04:53 PM
CO_VR4's Avatar
If nobody else mentions it, you also lose one joint when you go to either, which makes the articulation of the driveline less.
Old Oct 28, 2007 | 04:55 PM
Why not?? it will be an imrovement on any car at any stage of modification
It will help your drivetrain from shock, give you better gas mielage, save some weight of the car and give you some horsepower...
Old Oct 28, 2007 | 05:15 PM
GreddyEvo's Avatar
I agree, I will probably have my suspension and brakes totally done before moving on to anything else or the cf driveshaft for that matter. Right now, I dont have a need for any more power, but I do like shedding weight.
Old Oct 28, 2007 | 05:23 PM
Only if you replace the rear 2-pieces with a 1 piece. Supposedly, the DSS aluminum driveshaft will be a 2-piece.
Old Oct 28, 2007 | 07:04 PM
inco9nito99's Avatar
2-piece driveshaft from Devotuning.com $537.00, not aluminum or CF though .
Old Oct 28, 2007 | 07:33 PM
So if it's not aluminum or CF, what the heck is it? How much lighter than stock?
Old Oct 28, 2007 | 07:52 PM
dudical26's Avatar
It is one piece for the rear section instead of the stock 2 piece. This way you eliminate one of the carriers and save 15Lbs.
Old Oct 28, 2007 | 09:51 PM
BlueDemon's Avatar
Maybe magnesium??? Plastic???
Old Oct 28, 2007 | 09:59 PM
urBan_dK's Avatar
The price used to be a little higher. So, 2199$, tax, shipping $2500 still not worth it for 15lbs even if you use the 2:1 equation for sprung/unsprung your gonna spend $2500 for 30lb weight reduction? Not unless I'm 100% maxxed out looking for every last ounce of performance.
You realize the driveshaft is not unsprung weight, right?
It may be rotating mass, but it's definitely not unsprung weight.
