What exactly is P0401
Old Oct 29, 2007 | 05:17 PM
evovin's Avatar
I got this code today... I researched but theres no exact answer!
Is this code critical? It says insuffucient flow or something.... so i just cleared it! i noticed that before the check engine light appeared my car sounded like gona stall and i saw the drop of RPM too.
HOW CAN I FIX IT? or Is this just a random code that we get sometimes????....
Old Oct 29, 2007 | 05:21 PM
SilverShadow03's Avatar
Maybe this will help you out...
http://www.obd-codes.com/trouble_cod...n-flow-egr.php
Old Oct 29, 2007 | 05:25 PM
evovin's Avatar
thanks! where can i locate the these parts >>> DPFE sensor and EGR valve?
Old Oct 29, 2007 | 07:39 PM
evovin's Avatar
help
Old Oct 29, 2007 | 08:06 PM
EvoTech's Avatar
you have a vacum line disconnected from the bottom/backside of your throttle body. Common problem. You need to feel around a bunch to find it, but that is what causes this most of the time.
Old Oct 29, 2007 | 08:08 PM
Evoryder's Avatar
if the hose is loose. Ziptie it... you may need to remove the strut bar to get good access.
Old Oct 30, 2007 | 07:33 PM
evovin's Avatar
i will try to look for it tom. thanks guys!
Old Oct 30, 2007 | 07:35 PM
baggedtaco's Avatar
same thing just happened to me i checked on here and saw everyone was saying its a loose hose.... searched for like 10 mins to find it and just when i was about to give up i found it!! its a pain to find but 99.9% sure its the freakin hose!
