Please help!! TBE install as we speak!!
Old Oct 29, 2007 | 07:22 PM
o6RSEvo's Avatar
Hey guys I just got the buschur TBE and im having trouble removing the o2 sensor and the stock dounut gasket. ITs really hard to remove the o2 sensor, im using an adj wrench and its just not moveing!! i used pb blaster too! the gastet is tearing apart slowly..is there a better way to remove these? what tools are best for these too. Thank you for your help!!!!
Old Oct 29, 2007 | 07:35 PM
o6RSEvo's Avatar
bump! anyone?
Old Oct 29, 2007 | 07:42 PM
redza's Avatar
I used the 2 interlocking wrench method (19mm and 21mm I think). After spraying it with WD40 and letting it sit for a while, I then put the 19mm wrench open end on the O2 sensor. Interlock the 21mm open end with the 19mm box end that's hanging down and use it for leverage. Although, a few well placed kicks didn't hurt either!
Old Oct 29, 2007 | 07:45 PM
gggplaya's Avatar
usually when i can't get bolts out, i heat it up a little with a torch. They come right out. Considering exhaust pipes can see around 800 degrees normally, i don't think it would hurt.
Old Oct 29, 2007 | 07:49 PM
WICKed'N'EVO's Avatar
I use a extension pipe on my crescent ranch to break loose the O2 sensor.
Exrension pipe is like free muscle
Evoluvin's Avatar
wd40 or heating it up will deffinetly get it loose!
Old Oct 29, 2007 | 07:51 PM
pbc_2007's Avatar
an o2 sensor socket and a long *** breaker bar
Old Oct 29, 2007 | 07:53 PM
EvoHung's Avatar
leverage can be your friend in need when it comes to working on cars. Jack the car up high and use the double wrench method.
Old Oct 29, 2007 | 07:54 PM
rcheung's Avatar
To make thing easier just get an O2 sensor socket and it will come off easier. Also to remove the donut i just used a screwdriver. It is on there pretty good. Who cares if it tears apart. Your not reusing it are you?
Old Oct 29, 2007 | 07:55 PM
Celica2EVO's Avatar
For the 02 sensor, I also used an adj wrench, busted my nose open doing it on a lift, then I hit it the wrench a couple times with a hammer and it came loose easily. As for the donut gasket, take a pocket knife and just slide it around the bottom a couple times, and then just use the knife to pry it upward as you continue to slide it around the base!
...or like I mention above if you dont have the O2 socket, you can use the crescent ranch with a extension pipe.
Old Oct 29, 2007 | 07:57 PM
evoracingstar's Avatar
i hate these things there the pain in the *** if they get frozen! just spray the sh** out of it. wose comes to worse torch it up till it gets red. and make sure u have ur wrench near u aand it will come right out! do it really fast tho!
Old Oct 29, 2007 | 08:02 PM
edardnaekim's Avatar
make sure when u put it back on to use anti seize
Old Oct 29, 2007 | 08:04 PM
pbc_2007's Avatar
on manifolds i have always found that if i spray some of that pb blaster and some tri flow, something mixes and i let it sit there for about five min. and they always come rite out.
you do have to understand that the exhaust gets very high heat, i mean high.
and the crescent with an extended pipe works great. but the doubling up on two open end wrenchs, i have got pretty hurt doing this. be careful..
my .02
Old Oct 29, 2007 | 08:39 PM
badhabit90's Avatar
DONT USE AN ADJUSTABLE WRENCH. use a box end wrench so you dont strip the o2 sensor itself. OR go to the autoparts store and look for a o2 sensor socket. should come out then...
