logging on to evoscan makes my car run crapy!
Old Oct 31, 2007 | 05:20 PM
evovin's Avatar
Today I tried to log on evoscan and the car sounds like a boat! just like the sound when you have a boost leak and the maf sensor is off<<<ya thats the way it sounded! but as soon as i hit the stop log button it will run to normal again!
help guys! why is this happening when i log on to evoscan?
Old Oct 31, 2007 | 05:27 PM
cfdfireman1's Avatar
Disconnect the small white connector and try it again.
Old Oct 31, 2007 | 05:31 PM
evovin's Avatar
what white connector?
Old Oct 31, 2007 | 06:09 PM
there are 2 connectors one small, 1 bigger that goes to the OBD2. disconnect the smaller plug if it's connected.
Old Oct 31, 2007 | 06:13 PM
evovin's Avatar
ah ok! i will try that! thanks!
Old Oct 31, 2007 | 06:36 PM
VRSF Tiago's Avatar
where does the smaller connector plug into?
Old Oct 31, 2007 | 07:05 PM
next..
to the other one
Old Oct 31, 2007 | 07:44 PM
kreionic's Avatar
also try and reinstall evoscan. I had and issue when idling and I started the logger my rpms shot up to like 3k and when I stop it went normal. I just reinstalled it and it was good to go. That was a long time ago though
Old Oct 31, 2007 | 08:43 PM
DynoFlash's Avatar
Seems as if your version of evo scan may have been currupted
Running with the white plug should have no effect
As the gentleman above suggested - try to erase and reload evo scan
Al
Old Oct 31, 2007 | 08:59 PM
JohnBradley's Avatar
That or you are trying to log at baud rate other than 15625. If the WB is set to "debug" it will bounce it around toward 19K and for some reason this makes the car act like you are describing.
Or your version of Evoscan has an issue. I would check the baud first though.
Old Nov 1, 2007 | 09:18 AM
You're right Al...
it shouldn't have any effect, but I've seen sometimes it does, maybe with an older ver. of evoscan.
Al
Old Nov 1, 2007 | 09:21 AM
Ralph's Avatar
I had this happen to me random before, was using v99.. I was required to uninstall and reinstall the software for it to remedy the problem.
I suggest you do this also, I bet it works
Old Nov 1, 2007 | 09:26 AM
lemmonhead's Avatar
ya baud rate issue will make your car run funny, make sure its 15625
OG
Dec 15, 2011 03:48 PM
rdtech
Oct 4, 2009 08:25 PM
Stealth Ag
May 20, 2008 11:02 AM
