Installed Hallman Pro RX MBC
Old Oct 31, 2007 | 11:39 PM
bboy_RES's Avatar
i just installed my Hallman Pro RX MBC this morning. installation was pretty easy. i just had to remove my Injen pipe/intake and i had enough room to work with. before i installed the MBC i was boosting about 17 psi. i know evo's push around 19 psi stock so i assume i have a minor boost leak which i plan on checking once i replace my FMIC next week. when i installed the MBC it was turned all the way off and i was only boosting 11-12 psi. i turned the knob like 8 times and i boosted 15-16 psi so i knew the mbc was installed correctly. when i got home i switched the light spring to the heavy spring and turned the boost up to 18 psi. i guess my overall question is "is it okay for me to turn the boost up to 18-19 psi even if i have a slight boost leak?" technically my boost would actually be 20-21 psi if i didnt have my boost leak.
Old Nov 1, 2007 | 12:20 AM
bboy_RES's Avatar
let me know if any of you guys need help with the install.
Old Nov 1, 2007 | 05:11 AM
Ultimate CC's Avatar
fix the boost leak, crank boost to 21psi...
Old Nov 1, 2007 | 07:17 AM
kaonashi's Avatar
you'll be fine, as long as when that leak is fixed you dont peg 30 lol, i had a friend once on his gsx had greddy profec B boost controller and he had a boost leak for queit awhile and he keep turning it up and up and up, well one day i decided to help him fix his leak so yadda yadda 2 hours later we found that a coupler was wore out changed it, went for a test run and he pegged atmospheric pressure because he had messed up the profec B and the solenoid got stuck open LMAO ............ Boom
Old Nov 1, 2007 | 07:22 AM
FullOutPwr's Avatar
N/M... see you remembered to change the spring
Old Nov 1, 2007 | 07:39 AM
kaonashi's Avatar
Yeah mine didnt come with another springs...............
Old Nov 5, 2007 | 10:06 AM
Davo's Avatar
mine is sitting to come to me
when do u need to change the spring menaing, should i change it before installing it?
will be checking u when i install mine
Old Nov 5, 2007 | 10:11 AM
tweakdsm's Avatar
hallman is one of the best MBC out there, peroid.
Old Nov 5, 2007 | 01:02 PM
bboy_RES's Avatar
i changed my spring after my hallman mbc was already installed. i didnt realize that i would only be boosting 11-12 psi with the mbc turned off. it says that the lighter spring is good for increasing up to 5 psi and the heavier spring is used to increase a lot more.
Old Nov 5, 2007 | 03:30 PM
YzBrad99's Avatar
how did you run the MBC off the bov or what?
Old Nov 5, 2007 | 03:38 PM
MitsuJDM's Avatar
This may sound stupid, but check to see if your gauge is leaking. I had many instances where I would only boost 14psi, but the car didn't feel any "weaker". Turns out the vaccum line into the intake manifold kept getting a hole in it...
Could very possibly be a boost leak, but just be sure to check EVERYTHING!
Old Nov 5, 2007 | 04:19 PM
dubbleugly01's Avatar
couple things, if you have a boost leak, you'll run richer than needed, so yes, it "should" be safe. If you're only boosting 11-12#'s with it turned all the way down, maybe your gauge is off? It should be 14#'s. And the fact that you were only recording 17#'s when stock boost is closer to 19#'s also points to your gauge reading lower than it should.
Old Dec 28, 2008 | 01:48 PM
Turbodemon's Avatar
when do u switch out the springs on the hallman??
mine came with an extra heavier spring
i plan on boosting 21 psi on the stock 8 turbo
Old Jan 17, 2009 | 10:16 AM
TwoFour's Avatar
Take out the spring with it installed, make sure to watch out for the ball, it will pop out first chance it gets!
Old Jan 17, 2009 | 03:55 PM
TwoFour's Avatar
Which spring is better for a close to stock Evo?
