what is max boost?
Old Nov 4, 2007 | 01:11 AM
Asmodeus6's Avatar
Originally Posted by chaotichoax
also higher gears = more load
more load = more boost
/thread
Old Nov 4, 2007 | 01:13 AM
recompile's Avatar
Originally Posted by Evogasm
am i reading this right? the stock evo 9 turbo will do 30psi?
hmmm..so what if im running 100 octane,how much boost can I run?
Probably 26psi spike.... I've run 26psi on Shell 93, but with only 2-3° of timing at peak torque.
With 100 octane, you could tune for 26psi at 5-6° of timing at peak torque
Old Nov 4, 2007 | 09:47 AM
Evogasm's Avatar
^^nice!
Old Nov 4, 2007 | 10:22 AM
20Grockit's Avatar
+1
Old Nov 4, 2007 | 10:56 AM
Evogasm's Avatar
what kind of power will my Evo 9 SE lay down at 26psi on 100 octane? with intake,TBE,boost controller,fuel pump,bigger fmic w/ piping
Old Nov 5, 2007 | 07:38 AM
06EVOIX SE's Avatar
all depends on who tunes it, i expected more than i got
Old Nov 19, 2007 | 10:56 PM
06EVOIX SE's Avatar
bump still having problems
Old Nov 21, 2007 | 08:26 AM
06EVOIX SE's Avatar
bump
Old Nov 21, 2007 | 09:18 AM
mplspilot's Avatar
Originally Posted by 06EVOIX SE
bump
/thread
Old Nov 22, 2007 | 12:43 AM
06EVOIX SE's Avatar
that doesn't slove my problem i turn the boost up but it still won't go pass twenty psi in first gear
Old Mar 1, 2008 | 11:25 AM
06EVOIX SE's Avatar
still need help
Old Mar 1, 2008 | 11:41 AM
V.8MR's Avatar
maxxxxxxxxxxxxxxxxxxxxxxxxx
boooooooooooooooooossssssssssssssssssstttttttttttt tttt
Old Mar 1, 2008 | 12:25 PM
Warrtalon's Avatar
You don't have a problem - it's called boost taper and load. This is all very normal and would be obvious with a little research.
Old Mar 1, 2008 | 01:02 PM
C6C6CH3vo's Avatar
Go find out for yourself and datalog. Chose the boost with the steepest rpm slopes below detonation wether it be 3 psi or 140 psi
