Question for Forge DV owners
Old Jul 16, 2003 | 01:15 PM
RENN-ART's Avatar
Originally posted by tpm17
KK do you have a report on the testing of the different springs you said you might do? Talked with Tom from Forge and I must say they are really top notch people. They're sending me out the green spring which I did not recieve in my tuner kit, and we had a nice long talk about the different results people are seeing from their DVs. I currently have only an RMR air filter kit and the blue spring was causing a fluttering sound. I installed the yellow spring today and everything is great, but I'd like to know if I'm leaking boost pressure with a really soft spring. Tom said green is the softest, then yellow, then blue, and lastly red is the stiffest.
hm...
If you're trying to go to a stiffer spring, why are they sending you the green one? I thought Tom just corrected my table of stiffness above... He says that the green is actually softer than the yellow one..
Old Jul 16, 2003 | 01:27 PM
showard232's Avatar
I installed the Forge diverter BOV (polished) after reading project Evo report; ordered it from Vivid, it came on time and man is this thing built. I appreciate quality and this valve has it. I installed it exactly as the stock BOV which was leaking at about 1.1 bar and the leaking stopped, no fluttering very smooth. I didn't crack it yet as it seems to be working well, however if Forge recommends one spring over the other for our cars I guess I'll be buying their tuneup kit when they sort it out.
Old Jul 16, 2003 | 01:59 PM
ForgeMotorsport's Avatar
Emil,
just to clarify I am sending the green spring because the tuning kit should have come with three springs and the shims. He only received two different springs which left him with only three choices, yellow, blue(which was in the original valve), and red.
Old Jul 16, 2003 | 11:31 PM
RENN-ART's Avatar
duh!.. i gotta learn how to read!! lol
thanks tom!
Old Jul 17, 2003 | 05:22 AM
newevo8's Avatar
Forgemotorsport,
Thanks for the reply on this post. Your information and quality of service is appreciated. you now have a new customer.
Everyone seems to be pleased with this vendor.
Old Jul 17, 2003 | 05:54 AM
You are welcome!!
Old Jul 17, 2003 | 07:42 AM
Zeus's Avatar
I ordered mine direct from Forge Motorsport also. These are the kind of people who have a very loyal customer base... I wish the rest of the industry would take note. Good job guys
Old Jul 17, 2003 | 08:04 AM
timzcat's Avatar
Ditto.
I was impressed that he took the time to have a technical conversation with me about the springs and new piston.
To double check Tom, I picked up Mobil1 Synthetic Grease it's red and comes in grease gun tubes.
Thanks
Old Jul 17, 2003 | 08:14 AM
Yeap, that's the stuff.
Old Jul 17, 2003 | 09:23 AM
03EvoVIII's Avatar
Forge,
Here is a question that people may be contemplating, I am.
Is there a specific boost pressure rating for each spring?
Old Jul 17, 2003 | 12:05 PM
bs's Avatar
bs
what is the grease for?
Old Jul 17, 2003 | 01:50 PM
timzcat's Avatar
I you are replacing the piston you need to relube the o-rings for the new one since you will lose most of the grease on the ol piston.
Old Feb 15, 2004 | 02:20 PM
rblader86's Avatar
Is there a specific way you should orient the BOV? Should the vaccum nipple be pointing at the radiator or upwards? I have a flutter with green spring and no shims, and only an aftermarket intake. Stock boost. Is the flutter damaging?
Old Nov 4, 2004 | 02:57 PM
evodrifter's Avatar
I have the same problem with my VTA, im running the yellow spring with 2 washers in it, and i get low boost flutter, but when i floor it, it flutters as it gets to lower RPM's after the blow off. It didnt do it when i just had the yellow spring in there, so im confused. Forge, help?!
stimpy
12
Aug 23, 2007 10:04 PM
CT9AEvolution8
Aug 25, 2006 04:49 PM
2literturbos
Jun 28, 2004 10:08 AM
ammitsuevo
10
May 25, 2004 06:29 PM
twkwan
12
Jul 4, 2003 05:44 AM
