Stroker or Stroked short block?
Old Nov 8, 2007 | 07:03 PM
everlasting1239's Avatar
Im wondering if i should get the AMS Stroker Short Block: http://www.amsperformance.com/store/...roducts_id=689
or just the stroker kit: http://www.amsperformance.com/store/...products_id=94
Also what are the advantages of the short block(besides it can hold more power), i dont think it makes any power but i could be wrong.
thanks
james
Old Nov 8, 2007 | 07:34 PM
RoadSpike's Avatar
thanks
james
The difference between the kits is simple but neither kit assuming you install it perfectly would be any different.
Short Block:
In the short block everything is assembled professionally for you which means you get the motor and put it into the car.
Stroker kit:
You basically get to do it all yourself
- Dissembling the motor pulling all the components out
- Clean and degreasing the block
- Checking for bore size and proper clearances on bearings
- Filing down the rings to proper sizes
- Installing the bottom end with ARP studs
- and so much more steps i'm not going to remember here
End result is installing the stroker kit takes time patience and an iron will not to cut corners
Old Nov 8, 2007 | 07:46 PM
kngnothg's Avatar
Instead of a 2.3, you could go to a 2.6L
Old Nov 8, 2007 | 07:49 PM
Blue Evo 8's Avatar
Originally Posted by kngnothg
2.6L is nuts
Old Nov 9, 2007 | 04:39 AM
Kjarri's Avatar
what about going with a magnus 2.2L in stead of the 2.3L
Old Nov 9, 2007 | 07:49 AM
Soon2BEVO's Avatar
I think magnus is grossly overpriced. They are a great company, but their prices do not justify IMO. I would definitely stick with Buschur or AMS.
Old Nov 9, 2007 | 07:52 AM
Soon2BEVO's Avatar
Originally Posted by Blue Evo 8
2.6L is nuts
Yeah its nuts alright... you get to rev to what... 6500rpm
Old Nov 9, 2007 | 08:07 AM
sabastian458's Avatar
2.6l wont be able to rev like a 2.3, just like the 2.3 cant rev as high as a 2.0 (built 2.0 that is) If you didnt mind a long down time and trust your mechanic the go with the stroker kit. If not, then get the short block, easier, less to go wrong with, and it is built by IMO the best Evo shop.
Old Nov 9, 2007 | 08:13 AM
20Grockit's Avatar
id just buy the shortblock instead of the kit unless you like tearing your motor down to nothing.
ammarX786
Aug 6, 2008 09:29 AM
Paul Nelson
35
Jun 8, 2008 02:00 PM
crazyevo9
Jan 31, 2008 11:07 AM
vtsnake
Automotosports - Illinois
13
Feb 26, 2006 06:00 PM
AutoMotoSports
26
Dec 21, 2005 06:35 PM
