intake manifold removal
Old Nov 9, 2007 | 06:06 AM
robjeff25's Avatar
need some advice on how to remove the intake manifold; all the bolts are removed as well as the connectors/vacuum hoses; let me know it is just sitting there
thanks
Old Nov 9, 2007 | 07:28 AM
scheides's Avatar
EvoM Moderator
ya there isn't really a how-to on this out there, except for the instructions on AMS's site on how to install their VSR SMIM. Basically unbolt the strut-tower bar, misc hoses and connectors, unhook the throttle cable, yank off the fuel rail & injectors, unbolt the dipstick, and then unbolt all of the bolts holding it on.
Old Nov 9, 2007 | 07:35 AM
sabastian458's Avatar
did you get the two bolts on the bottom of the intake (connects to the bracket to help hold it up) If you pull your battery and tray out, you can squeeze it out that way without having to take the strut bar off. Make sure you get all the vacuum lines disconnected because you will brake the EGR solenoid (have done so, easy to miss)
Old Nov 9, 2007 | 07:37 AM
OKIX's Avatar
good luck with the lower bolts. That job is a pita!
Old Nov 9, 2007 | 07:43 AM
saiyanzzrage's Avatar
must be a PITA with the thing in the car
i unbolted mine from a blown motor when it was out of the car and it was annoying as hell...good luck
dubbleugly01's Avatar
yes, watch out for the support bracket below the manifold. It's hard to see from the top of the car. Those bolts are a pita to get to.l
Old Nov 9, 2007 | 08:08 AM
robjeff25's Avatar
yeah, i got the two bolts that are under the car; i dont really see anything else holding it on;
Old Nov 9, 2007 | 08:11 AM
Did you get ALL the bolts/nuts on the intake to head flange? there are like 12 in total. 2- 12 mm nuts, 2- 12 mm bolts, 2- 10 mm nuts, and like 4 10 mm bolts.
Old Nov 9, 2007 | 08:13 AM
PPI's Avatar
PPI
What about the nuts on the studs? The one by the alternator bracket could be overlooked.
Old Nov 9, 2007 | 08:15 AM
and the 1- 12 mm bolt holding the dipstick tube onto the manifold.
Old Nov 9, 2007 | 08:45 AM
robjeff25's Avatar
yeah, my dumbass has a little more work; just have the 4 bolts underneath; thanks for the help guys
Old Nov 9, 2007 | 10:15 AM
robjeff25's Avatar
any advice on how to the bolts off underneath the intake itself that is attached to the engine? got one off, but three to go;
thanks
Old Nov 9, 2007 | 11:13 AM
PATRICK B.'s Avatar
thanks
12mm ratchet style box end w/ ability to angulate, gotta do them mainly by feel
My forearms got some cuts due to squeezing it behind the manifold on connectors and clips etc.
Old Nov 9, 2007 | 11:31 AM
PPI's Avatar
PPI
if you are referring to the bolts that hold the i/m to the head, that you can't see...ratchet wrench is a good tool. Working by feel mostly. Make sure the coolant lines are out of the way so you can access them from drivers side of the car reaching under the i/m. I have also done it from under the car but that is even less fun lol.
Old Nov 9, 2007 | 11:33 AM
riceball777's Avatar
swaping intake manifold in and evo is one of the worst things i even done. its a pain.
