Air temp & MAP sensor questions
Old Nov 11, 2007 | 11:02 AM
dcshoeco's Avatar
Great! Thanks for your help! Im hopeing that hooking up the stock map and getting a boost control solenoid will clear up all the issues with my car. If not at least that part of this project car will be right.
I do have check engine light on but Im sure that no rear O2 sensor has something to do with that. I bought that Perrin rear O2 delete module but have not hooked it up yet.
Old Nov 11, 2007 | 12:23 PM
dcshoeco's Avatar
Wired up map sensor and barely made a difference. Guess I will order a boost solenoid tommorow and hope that helps.
Old Nov 11, 2007 | 12:51 PM
dubbleugly01's Avatar
stock map sensor (on the evo8) is only used for EGR control. It will not affect performance that you'll be able to tell. It has nothing to do with a/f or other functions other than EGR.
Not sure about a cel light will occur if you don't plug it in.
Old Nov 11, 2007 | 01:57 PM
dcshoeco's Avatar
Im not familiar with what the boost solenoid is. Does it just have the wire harness that plugs into it or do vaccum lines run to it too?
Old Nov 11, 2007 | 01:59 PM
cssaddictm4's Avatar
What are the symptoms of poor running? Can you go to a local autozone/advanced auto parts and have them and run a OBD check? It also probably does not like not having an O2 sensor in the rear.
Old Nov 11, 2007 | 02:00 PM
one vac line runs from the intake and the other to the wastegate.
Old Nov 11, 2007 | 02:05 PM
dcshoeco's Avatar
I have not scanned it yet because Im still trying to figure out whats missing or hooked up wrong. This car was gutted when I bought it and Im not familiar with the car in a stock state. After I get the boost solenoid in and my Perrin O2 simulator installed I should have things buttoned up enough to scan it and get a good idea of whats wrong.
Old Nov 14, 2007 | 07:48 PM
dcshoeco's Avatar
Can someone post a picture of the boost control solonoid or install instuctions so when I get it in the mail tommorow I will know how to hook it up? Or a diagram would help too. Thanks in advance!
Old Nov 20, 2007 | 07:02 AM
http://evomoto.com/tech_info.php?tPa...c68cb16c73916c
Familiarize yourself with that how-to to see how the stock boost control solenoid is connected..
Blake.
Tony Turbo
Oct 12, 2015 07:29 AM
tecker184
Jan 29, 2015 07:59 PM
napolean
Jul 18, 2011 10:10 PM
heaveho
Aug 19, 2010 03:15 PM
David Buschur
57
Aug 11, 2008 04:55 PM
