New record for pump gas, set with the HTA35r
Old Nov 13, 2007 | 01:42 PM
  #46
evilbada's Avatar
Originally Posted by Ted B
It was discussed here sometime ago that the UK tuners were running considerably more boost pressures than their U.S. counterparts, despite using a similar fuel to our 93 octane. When it was asked how U.S. tuners concluded that 22-23 psi was the max possible for 93 octane fuel, no one had a clear answer.
As the boost pressure is turned up, the ignition advance has to be reduced. At some point, turning up the boost pressure further won't yield any additional power, simply because the ignition retard will be too much. As to where this point typically occurs, it's never been made clear. . . but it appears to be significantly higher than what most of us expected, as you can plainly see in this discussion.
And I might add that turbo efficiency definitely is a factor here that cannot be ignored.
If this is true, I can just get a big *** turbo without having to spend money on meth/c16.
I can run on pump all day long!!
I'm also dying to find out if '93pump = meth power' is in the future.
Old Nov 13, 2007 | 01:48 PM
  #47
crcain's Avatar
Originally Posted by zl1560
Would you be willing to share how you are able to run so much more boost on 93 octane than everyone else?
How to Run Massive Boost on 93, by David Buschur
There is no secret here guys. Yes there is a lot that goes into what will make a car det. And in that perhaps some BR parts help the situation. But in general, as boost increases, ignition advance will need to be retarded. Just about anyone can run 30 psi on probably 91 if they wanted. But it would likely be the case that the ignition timing is so retarded your just hurting the situation at that boost level.
But for a well setup car and on a bit better gas like 93... Dave is finally showing people what can be done. How it has taken this long I dont know lol.
If you look at the guys in the UK, they run on 99 RON Shell V-Power which is according to any source I've read, equivalent to 93 PON. They run 2.2 bar boost on pump fuel maps! And they make 600+ hp at the crank on pump with those maps and a GT35R.
Now Dave is doing that consistently basically. Which is cool.
Old Nov 13, 2007 | 02:03 PM
  #48
Jax419's Avatar
Wow, amazing! thats some crazy power on your dyno with a 35R!
Old Nov 13, 2007 | 02:06 PM
  #49
Adam@MMS's Avatar
What kind of timing are we talking about here at max torque/max boost? 0 deg? negative numbers?
Old Nov 13, 2007 | 02:50 PM
  #50
icantdrive75's Avatar
Well lets see. If FP would ever call me back about the turbo, all I'd have to do is drive it 21hrs to Ohio. ****.
Old Nov 13, 2007 | 02:55 PM
  #51
dafoe69's Avatar
Originally Posted by dudical26
This is an interesting point. Do you have a link for reference to the original discussion?
I have been doing more tuning on 93 and have found that despite my old tune being at 21-22 psi I am can easily run 25psi with very little to no knock.
link for you and everyone to the thread Ted mentioned https://www.evolutionm.net/forums/sh...d.php?t=250559
Old Nov 13, 2007 | 02:59 PM
  #52
vwjeff's Avatar
Very nice man... to both of you.
Old Nov 13, 2007 | 03:00 PM
  #53
RazorLab's Avatar
Would love to see the EGT's on this car.
Old Nov 13, 2007 | 03:35 PM
  #54
mplspilot's Avatar
I'm pretty sure high boost has a lot to do with AEM EMS and knock sensor programming.
Old Nov 13, 2007 | 03:36 PM
  #55
mchuang's Avatar
Big T, big exhaust, low compression = low backpressure = more boost on 93octane.
Old Nov 13, 2007 | 03:41 PM
  #56
LV///R's Avatar
Pretty sure the built head isn't hurting things either (running high boost on 93 oct).
Old Nov 13, 2007 | 03:46 PM
  #57
TwStDeVo's Avatar
so if this same combination was ran with the cast mani, would it pretty much just yield around 30whp less?
Old Nov 13, 2007 | 03:56 PM
  #58
mplspilot's Avatar
Originally Posted by davidbuschur
BTW, my brothers car is running a STOCK EVO9 turbo right now. He has Stages 1-4, BR Race FMIC, two mufflers on his car too, the AEM EMS. 93 octane and 30-32 psi daily.
Dave, what cams are in that car?
Old Nov 13, 2007 | 04:37 PM
  #59
evo fred's Avatar
i wonder what kind of torque would come out if that car had a 2.3 stroker!!!!
Old Nov 13, 2007 | 06:27 PM
  #60
David Buschur's Avatar
The exhaust is not a dual exhaust, it simply uses two mufflers. One where the cat would go and one in the rear of the car in the normal position.
dead, the PCV in this car is operational and hooked up. Just the vent on the end is vented to atmosphere.
twstedevo, you are due for a trip to our shop anyway Come up, we'll change a few parts around and I will give you a tutorial on the AEM.
