Older blitz SBC boost controller
Old Jul 15, 2003 | 02:02 PM
w2pac12345's Avatar
I just bought this
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2421537450
I was wondering if anybody else has this model and if so if they could answer a couple questions about it. Everything seems to be easy to install.
What is the gain knob for?
What is the switch that says Wg arrow AC?????
What is the Pressure hole for?
Thnx
Old Jul 16, 2003 | 06:06 AM
Eric Lyublinsky's Avatar
Re: Older blitz SBC boost controller
Originally posted by w2pac12345
I just bought this
Thnx
Gain is how fast the boost builds. (tune this cafefully to much gain will give you spikes in Boost)
WG= Ext Wasgate AC= Int. Wasgate (stock turbo is AC use that setting)
Pressure hole?? Not sure what you mean about this but you need to tap the tee into a Mainfold Line or off the FPR. If you pop your hood you will see on the top of your cam cover (red one) and hard line with a soft rubber line in the middle (to the right top part of the cover) cut in the middle and stick your tee in. Now Blitz gives you this tee witch is smaller then the line so if you just stick it in it will pop out . I would sugest to carefull wrap the part that goes into the soft rubber line with Teflone tape. (make sure you don't cover the holes and wrap until it's a snug fit.). Then use the tinny zip ties that came with the kit to keep it sacure.
Now for the electical part is very easy. Ground and 12+ while ing. is on. The Blitz unit saves your setting even with out power in it.
My Very Best and good luck
Eric
Email me for my number and I will guide you throw the installation. I can't count how many times I have install these units on anything that has a turbo. This is my most Fav EBC of all time.
Old Jul 16, 2003 | 06:27 AM
Pic were you tap for pressure
Old Jul 16, 2003 | 08:59 AM
w2pac12345's Avatar
Thnx for the help. Install went easy. Took 3 hours.
Old Jul 16, 2003 | 09:01 AM
Good!! enjoy.
