GSC S1's or Cosworth 272?
Old Nov 15, 2007 | 03:29 PM
ModifiedMR's Avatar
You shouldn't need a head gasket or head studs unless you get a bigger turbo or alky.
Old Nov 15, 2007 | 03:30 PM
CoachG's Avatar
I know the lift on the Cosworths is fairly high (11mm?), so I imagine that springs/retainers/etc. would be required? recommended? for an VIII? IX?
Any hard info?
Old Nov 15, 2007 | 03:33 PM
schred86's Avatar
cosi's. done.
Old Nov 15, 2007 | 03:36 PM
tolga900's Avatar
i fit my car 1mounth ago and now with stock valfe spring and rtainersstock no proble in 7800-8000 in high rpms cosi best
Old Nov 15, 2007 | 03:37 PM
smp3000's Avatar
From my recent research I've found the S1's to be PERFECT for what I need. It's really a great cam.
Old Nov 15, 2007 | 05:05 PM
Str8Nasty's Avatar
So if you were to get the Cossie Cams. ANd Raise your Limiter to 8k. Your going to need springs/retainers and headstuds correct?
Old Nov 15, 2007 | 05:58 PM
AKgambler47's Avatar
Well i answered my own ? and im going with cosis. I am getting either ams or arp headstuds, cometic head gasket, and single spring and retainer kit.
Old Nov 15, 2007 | 06:05 PM
sliqdaddy91's Avatar
keep in mind peak numbers aren't always the best...area under the line is and thats why i chose GSC S1's ftw!!!!
Old Nov 15, 2007 | 06:09 PM
Qatar_Evo's Avatar
I have the GSC S1 and i love them so much
they work fine with maxmim 50trim so if you wanna be in the 400 you will get
an Evo green mostly and they will work really good
they are the best thing i ever did to my Evo
Old Nov 15, 2007 | 06:17 PM
merkzu's Avatar
I love the S1's. They run very smooth, idle like stock and make good power for me on the stock turbo.
This was on a dyno dynamics, add 12-15% for dynojet
Old Nov 15, 2007 | 06:51 PM
Well i still have a couple of weeks til i get them cuz i am getting a JMF intake manifold first in two weeks. So maybe someone can talk me into different cams. But i am seeing the cosis the best choice
Old Nov 15, 2007 | 06:55 PM
9sec9's Avatar
Within 2 weeks, I'll have a complete comparison of HKS 272's, Cosworth's and JUN 272's on a IX. Dyno'd results and all.
Old Nov 15, 2007 | 07:38 PM
homiusang's Avatar
Old Nov 15, 2007 | 09:24 PM
EVIL_EVO_VIII's Avatar
All i have to say is Cosi!!! Look at my sig and whp#s on pump gas 93
Old Nov 16, 2007 | 09:14 AM
Str8Nasty's Avatar
^^^ How many PSi you running with that. Not bad at all.
