Gear Lockout?
Old Nov 18, 2007 | 03:10 PM
1NastyMR's Avatar
Gear Lockout?
After driving on the hiway for about 20 minutes I exited and as I'm driving and try to shift into 5th gear it wont go in. I keep trying and it wont go in but its not grinding or anything. This morning I go to work and shift 5th and it works fine? Whats this about.
Old Nov 18, 2007 | 03:11 PM
JordanS4's Avatar
new clutch? adjust the pedal.
Old Nov 18, 2007 | 03:21 PM
CO_VR4's Avatar
Do you have the stock bushings at the transmission end of your shift cables, or did you replace them with the solid bushings? Several people have reported mechanical lockout due to the solid bushings seizing up sporadically. Take a look under the hood, maybe disconnect the shift cables and see if they're going back and forth smoothly, check the transmission shift linkage movement with the cables off and see if they move freely, and you'll have a good idea whether it is a linkage or cable issue, or whether it's internal.
SWOLN's Avatar
Check your mastercylinders' fluid level.
Old Nov 18, 2007 | 05:18 PM
iturregui's Avatar
If it was the clutch it would grind. It sounds more like a linkage problem
BlueoctaneevoX
25
Oct 12, 2011 09:56 AM
pb91
Jun 8, 2011 02:44 PM
Evo3573
17
Nov 14, 2010 09:47 PM
chase123
Feb 9, 2009 09:00 AM
KazzEvo8
10
Jan 24, 2007 12:37 PM
