Cam Suggestions gt-35r stock 2.0
If you are retaining the stock head and valvetrain, the HKS 272, 280, or GSC S1 is what you'd select.
whatever you'd like to go with, there are so many choices out there... you can even go with hks 264 if you want. but if you want most hp, and don't mind upgrade spring/retainer, go with the most aggressive ones, it will give you the most hp, it's a very easy choice.
AMS time attack car is using Jun 272's but off course its stroked!
look>>>> http://cgi.ebay.com/ebaymotors/AMS-T...QQcmdZViewItem
Depends on the application, if it is all about a peak number or drag racing number than I would probably say go for the S2 cams. If you end up with a larger turbo or a ported head and a built 2.0 or even a stroker then that is the cam you would want to use.
If the car is going to stay on a stock head and 2.0 and a GT35R, I would run a set of S1's. I think the power under the curve of the S1s on a GT35R is pretty damn impressive especially on a stock long block setup.
Greg,
how much more hp would the s2's put out? im looking at keeping it 2.0 and sticking with the gt-35r perhaps down the line building the 2.0. the car is daily driven and would like a suddle change in idle but manageable in stop and go traffic. If it is possible to put 500whp to the ground on s1's i will do that. i dont want to loose any low end or mid-range power
Greg,
