problems
Old Nov 22, 2007 | 05:40 PM
20Grockit's Avatar
problems
yeah my boost wont build above 14-15 psi and theres no power to the car whatsoever. the boost will spike to around 14-15 and fall to around 12 and stay there. the car has no pull. its like its bogging. anybody got a input
Old Nov 22, 2007 | 05:45 PM
drano7823's Avatar
Have you checked for any boost leaks or has one of your intercooler pipes maybe popped off?
Old Nov 22, 2007 | 05:48 PM
iturregui's Avatar
Boost leak test. With the bunch of mods that you have listed I guess it should be easy for you to perform said test. Have you changed anything in the wastegate line or something?
Old Nov 22, 2007 | 05:54 PM
20Grockit's Avatar
i dont have that t3/t4 kit on yet. im still running my 20g9. boost is set for 23. when i floor it, it misses around 5-6k. havent changed any wastegate lines. ill do a boost leak test and check it out. if thats not the case what else could it be??
Old Nov 22, 2007 | 06:26 PM
iturregui's Avatar
Any CEL. Hard to tell without more info
Old Nov 22, 2007 | 07:56 PM
20Grockit's Avatar
yes i do have a cel. not sure what the code is. im gonna stop by my buddy's house tomorrow. hes got a scan tool. i had a code about 2 weeks ago. i think it was p0401 which is insufficient egr flow. it also had a code that there was a misfire on cylinder four but that was just a loose connection on the injector plug. i took care of that and reset the ecu and didnt have any cel til today. i dont know if maybe the p0401 came back up or not. im gonna check it out tomorrow. i dont think that would have any affect on my boost though would it???
Old Nov 23, 2007 | 06:07 PM
20Grockit's Avatar
i tried to get the stuff together for the boost leak test today but i couldnt get hold of the rubber coupling. i got the pvc cap and the valve stem. im gonna give it another shot 2moro. still got a cel on. im gonna take off the egr valve and clean it even tho i dont think it has anything to do with my problem.
Old Nov 23, 2007 | 06:11 PM
Ultimate CC's Avatar
definitely sounds like a boost leak...
Old Nov 23, 2007 | 06:14 PM
Evoryder's Avatar
^ +1 ...
Old Nov 23, 2007 | 06:29 PM
20Grockit's Avatar
thanks for the input guys. oh and ultimate cc i got those injectors today. thanks for the quick responses and fast shipping. injectors are in good shape. im gonna put em on the flow bench tomorrow
Old Nov 23, 2007 | 06:33 PM
sounds good, ill drop you feedback now...
Old Nov 24, 2007 | 07:57 AM
20Grockit's Avatar
hey i dropped you some feedback as well man. i really appreciate everything and awesomely fast shipping. im putting those in this weekend. i just got a new aeromotive fpr as well that im installing this weekend.
coreymelton
May 16, 2015 05:41 AM
ARS
Dec 17, 2013 11:10 PM
polish_pounder
Jul 14, 2011 06:17 AM
riksride
Jun 16, 2010 12:32 PM
evodave
May 10, 2009 04:57 PM
