Build!!! What else am I forgetting?
j/k i can do this.i've taken off the head many times. done it in half a day. from there it's just taking off the oil pan, rods, pistons and measuring the bores and the new pistons to get the correct clearances. pretty simple.
i'm not replacing main bearings. to do them, i'd either have to use a roll-out pin (which i don't want to do it that way) or take off the tranny to be able to get the crank out of place and get at the bearings.
ttp, your pistons look like a great upgrade over the wiseco's. i wish you would have came out with them sooner though. i am now just out of money...you guys are great though!
I just finished installing buschur rods and pistons in my friends car. We did the build in car. Cam out very nice. Only difficult part was setting the timing back up after rotating the motor after each rod and piston went in to make sure it was smooth. All that work can be done in a day if need be.
One thing i was always advised to do is to not run the Iriduim plugs on higher than stock boost levels, and other mods.... I have a 2.3L stroker, 35r, hks 272 cams, ems, and tons of other thing, and i made on pump 526 awhp on 20 psi, and 630 awhp on 29 psi on race gas (C-16)..... I'm running just the NGK BPR8ES, and now have just tried the BPR9ES.... I would use this plug instead of the Iridium plug
anyways, at that time, i was having a boost leak and found out my wastegate actuator wasn't holding boost at all. most i was boosting that day was 15 psi.
