Instlled HKS Type 1 TT now its not working?
Old Jul 17, 2003 | 09:32 AM
EVO VIII Chris's Avatar
The other day I installed my HKS Type 1 Turbo Timer. I followed Vanilla Skys right up on here and everything went well. I didnt have a harness so I made my own and I located the 12 volt constant, ignition, and accesory. I wired everything up and turend the car on. Before I shut the car off I pulled the Ebrake and took it out of gear and shut it down then. When I shut it down the Turbo Timer started flashing while it was counting down from 30 seconds. The car WAS NOT on however while it was doing this though. The only thing on was the clock and the CD player and all the accesories! It counted down to 0 and then everything went off including all the accesories. I tried it again this time in the middle of the countdown I took the E brake off and it immediatley shut down which tells me for sure that the E brake wire is hooked up right. I know I also got the ECU wires right because when you drive it tells the RPMs and speed and everything. Can anyone tell me where I went wrong???
Thanks
Chris
Old Jul 17, 2003 | 10:26 AM
Mad_SB's Avatar
I don't think you use the acc line. THe evos have two ignition leads IG1 and IG2. I have a diagram posted in the troubleshooting section under the post double check my tt wiring.
I think normally the tt will send 12v to the acc line to keep the engine running but since this car has two ignition leads you have to use one of them instead of the acc line. Your timers manual should clarify that.
beast66
Feb 15, 2016 12:51 PM
bboy_RES
Dec 21, 2007 11:55 AM
vr4_211
Dec 4, 2005 09:22 PM
usaevo8
10
Aug 26, 2004 08:21 PM
EVOtook
Sep 1, 2003 09:43 PM
