Do I need a Fuel Pump
Old Nov 28, 2007 | 07:53 PM
destro92179's Avatar
With TBE, drop in filter, and Boost Controller would I need a walbro fuel pump even tho Im runnin stock injectors. I am currently gettin tuned and we will not continue until I get the fuel pump. Thanks in advance
Old Nov 28, 2007 | 07:59 PM
TTP Engineering's Avatar
If you add a fuel pump after the tune you can throw off the AFR's.
Depending on boost level and the intake air temperatures, you can over-run the stock pump easily under the correct conditions.
Old Nov 28, 2007 | 08:37 PM
Thx.... we are not done tuning yet he is actually waiting for me to get the fuel pump before we continue.
I was curious as to how much of an affect the fuel pump will add to the tuning process since my injectors are stock.
Old Nov 28, 2007 | 08:54 PM
4WS Tuning's Avatar
its a quick fix
Old Nov 29, 2007 | 02:16 PM
Neuspeed06's Avatar
Funny, Al wouldnt even flash my ECU without a fuel pump when i was stock. lol
Old Nov 29, 2007 | 02:18 PM
He changed his policy after Stew blew his engine with a stock pump.
Old Nov 29, 2007 | 02:20 PM
Tsurugi-san's Avatar
Get the pump.
Get the tune.
In that order.
Old Nov 29, 2007 | 03:37 PM
(GSX95)'s Avatar
Originally Posted by Tsurugi-san
Get the pump.
Get the tune.
In that order.
X2
Old Nov 29, 2007 | 04:36 PM
feldguy's Avatar
the pump is relatively cheap, will lay the ground work for a long time to come, until you outflow the fuel pump, and its an easy install for the most part.
It will enable you to tune a little more agressively, and thats always a good thing.
Old Nov 29, 2007 | 07:45 PM
dubbleugly01's Avatar
good plan, wait for the pump. With enough boost and cold weather, even on stock injectors, the walbro vs. stock pump will make a difference at high injector duty cycles and throw off the tune.
Old Nov 30, 2007 | 07:53 AM
xxNosTankxx's Avatar
Pump then tune then power
Look in my sig, same mods i have a IX so your number might be a little lower.
Old Nov 30, 2007 | 11:46 AM
Canexican's Avatar
I've seen just the pump for like 80 - 100 bucks, quick question: Do you need to get the pump with the "evo specific" install kit or can you go with just the general kit. I'd rather spend 80 bucks than 120 bucks if I can help it. Thanks.
Old Nov 30, 2007 | 02:51 PM
u dont neeed the kit but I thought it made for an easier and cleaner install. I dont know where your looking for it but I got mine with the kit for $95. I think it was off ebay but i dont remember
Old Nov 30, 2007 | 03:43 PM
20Grockit's Avatar
definately get the pump before the tune. are you gettin a reflash or what???
Old Nov 30, 2007 | 03:57 PM
dancarroll0283's Avatar
Get the 255
