How much more whp using meth?
Old Nov 28, 2007 | 07:54 PM
CrackerJackToy's Avatar
Im looking to get possibly meth as my next mod. I think I should take everyones advice, and max out my current 9.8 hotside turbo before switching out to a larger GT30 setup later next year. With all the mods listed in my sig, how much whp gain am I looking at? Will be using 93 octane gas.
Currently im at:
335whp / 312wtq on 93 oct.
Old Nov 28, 2007 | 07:56 PM
EMonz57's Avatar
Might want to add what type of gas youll be runing with it 91-93 and what type of gas the Dyno#s were on as well
Old Nov 28, 2007 | 07:57 PM
TTP Engineering's Avatar
25-40whp with properly set up meth injection system/tuning on factory turbocharger.
Old Nov 28, 2007 | 08:05 PM
Updated.
Old Nov 28, 2007 | 08:11 PM
kouzman's Avatar
Question about meth injection...
Lets say that you have tuned your car to have zero knock @ 23psi boost... If you raise the boost to 25psi you get knock... What nozzle and kit would you need to use in order to supress knock?
In other words, could you use meth as a knock suppresant and have any whp gains just from the boost raise? I would assume that you have to use a small nozzle which makes meth to last longer and the tune is not to the edge of destruction...
Old Nov 28, 2007 | 08:13 PM
Mulholland0132's Avatar
I have the 10.5 hotside on an viii turbo, hks 280/280 cams, BR race fmic, and straight alky. My numbers are in my sig. if that helps.
Old Nov 28, 2007 | 08:19 PM
mrdevo's Avatar
I would say you would be around 370whp/380trq with a bit of boost-28psi
Old Nov 28, 2007 | 08:23 PM
Blue Evo 8's Avatar
On my 50 Trim EVO 8 I made 410 AWHP w/o meth with just 21-22 PSI and 93 octane gas...... with the meth turned on and boost turned up to 28-29 PSI, I made 86 More horse to the wheel....
Old Nov 28, 2007 | 08:45 PM
Not enough information provided. AFR, IGNITION TIMING, CAMGEAR DEGREE SETTINGS, INTAKE AIR TEMPS etc would be useful information.
Old Nov 28, 2007 | 09:02 PM
kouzman's Avatar
afrs: flat 11, 10.8 after 6500
ingition: 5-7 @ peak torgue, up to 16 after 7000
mivec cam setting with cossie cams
spike 23psi 0 knock everywhere on Shell V-power 93
When i up the boost lets say to 25psi the car has knock, but when i use my Torvo additive i get 0 knock again, with some occasional 1s...
i was wondering if i could have the same effect with meth injection...
Old Nov 29, 2007 | 07:14 AM
Jeff_Jeske's Avatar
Instead of overworking the 9.8 turbo at a minimum just do the 10.5 hotside. With the cams you have you should see a nice handsome increase in power across the entire power band.
The mod is super easy to install and huge bang for buck with NO RISK of bad things happening. Even if you put alchy on your current setup you still aren't going to see the airflow that you need up top with that 9.8 hotside.
The 10.5 is a big bang mod. Add in the SS O2 housing with no additional work and you'll pick up even bigger power.
Old Nov 29, 2007 | 07:27 AM
KevinD's Avatar
the gains with meth for the stock turbo will be good. you'll see huge torque increase, like 40-50ftlb. that is of course assuming you spike the boost pretty high (like 30psi). but because the stock turbo runs out of steam the HP gains up top are not as significant. like what ttp said, around 25-30whp.
when you drop in a 30r though, the meth improvement will be huge, like 60-80whp increase. so the meth is a good mod because it will help you out big time if you go to a big turbo, yet still be a blast to drive with the stock turbo.
Old Nov 29, 2007 | 07:35 AM
Ultimate CC's Avatar
+1 to that, meth makes the stock snail a different animal...
saiyanzzrage's Avatar
30 - 40 whp i saw on my ix with 93 octane, stock turbo. Saw about 40 - 50 increase in torque. This was at 28psi, AMS custom road tuned
Old Nov 29, 2007 | 08:57 AM
Yeah I was thinking of doing meth on the 9.8 (Going with the Aquamist HFS-1 kit), and then afterwards saving up some cash a few months later & getting the 10.5 hotside and o2 housing at the same time. I want a very conservative tune and looking to turn the boost up to 27/28 max since its so tiny.
Then later next year, probably after summer ill be looking into the GT30R kit.
