Rattling & Vibration from TC
Old Nov 30, 2007 | 12:27 PM
spudlus's Avatar
Guys:
Do you know if the bearings in the Transfer Case are changeable? I've getting a rattling coming from the Transfer Case, no, not the "death" whine that I've heard before. It sounds more like a bad bearing. Are these changeable?
Also the fluid that's in the TC, apart from the ring and pinion, what else does it lubricate?
Thanks!
Old Nov 30, 2007 | 06:02 PM
spudlus's Avatar
Anyone?
Ttt
Old Dec 1, 2007 | 05:06 AM
spudlus's Avatar
Ttt
Bueler...........Bueler............Bueler
Old Dec 1, 2007 | 05:13 AM
Evoryder's Avatar
Nothing else lubricates the transfercase but the TC fluid that you change every few 1000(4 for me) miles. Are you sure it's the transfer case and not the wheel bearings...
TC = gears on gears on gears
Old Dec 1, 2007 | 07:41 AM
spudlus's Avatar
Thanks but you misunderstand, specifically what else apart from the ring and pinion INSIDE the TC gets lubricated. There must be bearings suspending the gears. Are they also lubricated by the gear oil?
Yes is the transfer case!
Old Dec 1, 2007 | 10:16 AM
Evoryder's Avatar
What else is going to lubricate it? What ever gears/ metal on metal that create friction and heat will be coated and lubricated by the transfercase fluid. There is not bonus fluid that I know of..
Old Dec 1, 2007 | 10:50 AM
rcheung's Avatar
There is a bearing in the tcase that can go. Its above the ring gear which I circled in this picture. But I do agree with evoryder that it is more likely a wheel bearing a tcase bearing.
SyncdLancer
Sep 29, 2016 04:39 PM
9!'clipseDOHC
Apr 3, 2015 10:19 PM
Lazeum
Sep 2, 2007 10:52 AM
VIIImylunch
Jan 29, 2006 02:49 PM
HiRevnVIII
Aug 5, 2005 07:50 AM
