Ralliart Clutch
Ralliart Clutch
Hi, has anyone around here had any experience on the twin ralliart clutch?? I've been considering it for some time, as my clutch is about to need replacement (not much power, but quite some track use and 4wheel slides aplenty). Any other options?? (Exedy twins aside...) It'll be holding some 380-400whp at the end of summer, so I don't wanna change it again, at least, not too soon
basicly there is 2 types of ralliart twin plate.
the one with light weight flywheel and another model which is not.
i am running currently the lightweight, and it is excellent and never sliped. my car is 2.3 and i am racing on full slicks in Autox with 6500 rpm lanches and it never showed any problem.
the light weight type is very noisey for evey day use. my friend is using the other type also in autox and it is perfect without noise.
i recommend these clutches although they are a littel bit expensive but in my experice better than exedy twin. (Ralliart are actually made by exedy but to thiere specs).
i hope this helps you.
