Witch one should I get?
Old Oct 30, 2007 | 08:02 PM
dsm25psi's Avatar
I have choice right now to get 3 three different set ups and they are both around same price, witch one should i go with and im planning to run only pump gas on any of these turbos,
Evo 8 20G-LT TME with 10.5 hotside ( I don’t where this turbo power is rated at, anybody?)-used
EVO 9 20G Turbo 10.5 Single Upgrade (rated at 450)-new
Agency Power Mitsubishi EVO T3/T4 Complete Turbo Kit 50trim (used)
Old Oct 30, 2007 | 08:06 PM
JDMCT9MR's Avatar
I would say whichever turbo that is in the best condition.But I guess if they are the same price its up to you.
Old Oct 30, 2007 | 08:09 PM
dsm25psi's Avatar
Would the Agency kit make more power then the other turbos?
Old Oct 30, 2007 | 08:39 PM
JDMCT9MR's Avatar
According to the info on the Agency power site it makes quite a bit of power.
Old Oct 30, 2007 | 09:51 PM
dsm25psi's Avatar
yea plus killer price too.
Old Oct 30, 2007 | 09:56 PM
h.funk's Avatar
50 trim if your gonna use it for track days
Old Oct 31, 2007 | 06:34 AM
dsm25psi's Avatar
evo 9 20g is rated at 450 and the agency 50trim is about the same power just want to get some ideas about witch one should i get.
Old Oct 31, 2007 | 06:40 AM
04KWAK636's Avatar
Originally Posted by dsm25psi
yea plus killer price too. new 3200 and i can get it for 900
Damn...did it fall off the back of a truck?
Old Oct 31, 2007 | 06:52 AM
suekie's Avatar
I would go with the EVO 9 20G Turbo 10.5 Single Upgrade (rated at 450)
I don't think you are going to be making much more power than 450 on pump gas. Also because that turbo is new, and the others are used. Forgot to mention, this turbo has pretty good spool up.
Old Oct 31, 2007 | 06:58 AM
dsm25psi's Avatar
lol, no i just got lucky with it found the right person who wants it gone fast,
Old Oct 31, 2007 | 07:00 AM
dsm25psi's Avatar
I just cant find a lot of info about it, it seems like everybody goes with green of 20g lt so i dont know how good is it and if you really can make that power on it, do you know anybody who used it?
Old Oct 31, 2007 | 09:52 AM
gsrboi80's Avatar
Most will tell you if you are going to go with the 20g IX get the 5 blade not the 6. Though there is alot of biased info on this so it seems by every thread I have read on here.
No one has raw data posted that proves anything
I bought the 6 blade 20g IX from a member on here for a great price and it is 100 times better then my 03 9.8 set up. Most say it will make as much power as a stock IX turbo but since I got it for that price it was worth it to me and have pulled on many of EVO IX's around the way
If I was buying a brand new one I wouldnt have bought the 6 blade but for the price I got it for and the power over the stock VIII 9.8 it was more than worth it
Old Oct 31, 2007 | 11:03 AM
PVD04's Avatar
This turbo does not exist. It might be an Evo 8 20G with 10.5, but the larger turbine (LT) has never been made in Ti-Al.
-Paul
Old Oct 31, 2007 | 11:17 AM
dsm25psi's Avatar
-Paul
http://lancershop.com/customer/produ...&cat=17&page=1
Old Oct 31, 2007 | 01:28 PM
PVD04's Avatar
Exactly. That is not a 20G-LT TME. That is a 20G-8-6 TME. It'll surge terribly. If I were you I'd go with either the Evo9-20G or the 50-trim. The 50-trim will provide more power at the expense of slightly slower spool. Depending upon your priorities, either one could be a good choice.
-Paul
