Perrin High Flow Cat
Old Dec 3, 2007 | 07:39 AM
CroatianKid's Avatar
I was wondering will this cat throw a code since its bigger than the stock one. Cause I plan on still using the co2 sensor. So if I hook the co2 sensor back up will it throw any type of code?
Old Dec 3, 2007 | 10:18 AM
XK120's Avatar
It will most likey throw a code after a while, although no code will be "thrown" if you ustilize a mechanical o2 fix
Old Dec 3, 2007 | 10:46 AM
Erik@MIL.SPEC's Avatar
Many cats that flow higher than stock throw the 0420 code.
Old Dec 3, 2007 | 04:54 PM
evo_k's Avatar
I have the Perrin HFC and I did get several check engine light. I added the O2 'mechanical fix' and it no longer throws the code.
Old Dec 3, 2007 | 04:56 PM
06rs_power's Avatar
just take out the sensor and have the cel flashed out
Old Dec 3, 2007 | 05:03 PM
CBRicahrd's Avatar
Its a Oxygen sensor. Not a CO sensor.
Not trying to be an ***.
Old Dec 3, 2007 | 05:12 PM
A CReader is more expensive, but will also work.
Old Dec 3, 2007 | 05:31 PM
mixmasta's Avatar
I used the "o2sensor simulator" and havnt had any problems. I think the website is o2simulator.com its an easy install and it takes care of any future code problems. Cheap too!
Old Dec 3, 2007 | 05:55 PM
MondoBongo's Avatar
i am currently using that cat in combo with an HKS Carbon Ti catback and invidia 3" downpipe.
it will occasionally throw the 420 code, and i am not sure why.
i will go months without seeing it, then once in a while, seemingly out of nowhere it will throw it, and if i reset it, or just drive around for a while it goes away.
my only guess is that weather has something to do with it. it seems more prone to happen when it is really hot ouside, like 90+, or when it is really cold outside, like 25 or below. but like i said, only occasionally.
generally it is good about it though, and i passed inspection at the dealer with it, so it's a good choice for a high flow.
Old Dec 4, 2007 | 09:28 AM
My bad on mixing those two up. It was late at night and had a long *** night. So should I just get flashed out, or get the o2 mechanical fix thing?
Old Dec 4, 2007 | 09:38 AM
EVOM3's Avatar
I have the Perrin HFC and Downpipe. It didn't throw a cel until recently. I did the mechanical fix which is very easy to do and its been fine ever since.
Old Dec 5, 2007 | 11:14 PM
Where can I purchase or get one of those mechanical fixes?
Old Dec 5, 2007 | 11:28 PM
c kim's Avatar
just get 2 spark plug anti foulers, drill one out with a 1/2 inch drill bit. screw the drilled out one onto your o2 sensor, screw the other one on top of that and then screw the whole thing into your exhaust. (exhale) I forget the thread size though, for the anti foulers.
Old Dec 10, 2007 | 07:49 PM
nothere's Avatar
about to do an obd2 license test. hi flow cat and mechanical fix, we will see.
Old Dec 10, 2007 | 08:35 PM
JDMCT9MR's Avatar
I've had the Perrin 3" HFC with all the mods in my sig for about 4K miles and have not had 1 CEL.I do have the O2 CEL fix and the car runs perfectly.You will be fine.
