no boost?
Old Dec 4, 2007 | 10:32 PM
Deepseadiver's Avatar
If you keep driving it around it should throw an Check Engine Light. Have it pulled and you'll know your problem. Check the intercooler piping again, also the vacume lines. Is you air filter clogged??
Old Dec 4, 2007 | 10:41 PM
SPOOLEDTSiAWD's Avatar
check your dv and make sure the hose it on tight and make sure its not just sitting in the recirc hose. That happened to my evo and it would build boost at all
Old Dec 6, 2007 | 07:04 AM
Adam@MMS's Avatar
Originally Posted by macho17
well i changed the spark plugs and i feel like a dumb *** for not remembering to do that when i did my last oil change, so i puttering is prolly good now but idk for sure because the boost is out right now and i cant get it to come back. After i changed the spark plugs and didnt get boost i unhooked the batter to maybe get some kind of reset but still no luck with the boost. Ne more ideas??..........one more little side note, before the boost went out today when i made a hard pull my dipstick shot out under the hood a shot alot of oil, dont know if that was jus coincidence or related some way.
Not to scare you here but as far as I know a dip stick popping out could mean internal engine trouble. Might be time to bite the bullet and bring it to a mechanic who knows their way around an Evo.
