no boost?
Old Dec 3, 2007 | 06:51 PM
macho17's Avatar
no boost?
So i was driving down the road and when i got on the gas a lil bit it got kinda choppy like it was puttering or something. So i got it hard to see if it would clear itself out, and it eventually does but around 5k rpm it still putters around. So i made a couple more pulls and the same, but then a lil bit down the road the car wouldnt make no boost. I figured an intercooler pipe popped out of a gromment or something but then the next day boost came back. Then it was fine for a couple days but tonight i got on it again and it was puttering again and then the boost stopped again. So i did a couple of pulls with the gas all the way down and took it close to red line and boost came back. Ne one have ne idea whats goin on?? Ne info is appreciated.
Old Dec 3, 2007 | 06:55 PM
CGK's Avatar
CGK
What are your mods?
Old Dec 3, 2007 | 06:59 PM
gilliam's Avatar
Old Dec 3, 2007 | 08:16 PM
macho17's Avatar
oo sorry.............hks intake, cusco turbo pipe, ams lower intercooler piping
hallman mbv, 3" O2 housing, 3" B&B turbo-back, 10.5 exhaust housing, hks 280 in/ex cams, smc methanol injection, zeitronix wideband, dynoflash and WORKS Pll, evoscan 9.0.
Old Dec 3, 2007 | 08:54 PM
UDLOZ2's Avatar
on agian off agian boost? tough one, i am guessing the waste gate actuator??? my 2 cents, good luck
Old Dec 3, 2007 | 08:57 PM
hksevoix's Avatar
besides boost not hitting did the car run like normal??
Old Dec 3, 2007 | 09:02 PM
macho17's Avatar
it runs normal except wide opent throttle...........then around 4 or 5k it putters a couple times and then smooths out.
Old Dec 4, 2007 | 09:07 AM
macho17's Avatar
need help please.........
Old Dec 4, 2007 | 09:22 AM
Adam@MMS's Avatar
Your symptoms described in the first post don't really fit this perfectly but boost cut maybe? Or fouled plugs?
Old Dec 4, 2007 | 09:49 AM
mplspilot's Avatar
1.Boost leak
2. Get new spark plugs.
macho17's Avatar
whats fouled plugs?? just bad spark plugs?? What causes boost cut??
Old Dec 4, 2007 | 09:50 AM
macho17's Avatar
Originally Posted by mplspilot
1.Boost leak
its not like a leak, its all or none........
Old Dec 4, 2007 | 09:58 AM
TeStUdO's Avatar
Sounds like your plugs are fouled. Change your spark plugs.
Old Dec 4, 2007 | 05:22 PM
20Grockit's Avatar
i agree it could def be the plugs. what plugs are you running?? if youre running copper or platinum, ditch those things and invest in some iridium. iridium withstands more heat than the copper and platinum which in turn means it has a higher melting point.
Old Dec 4, 2007 | 09:43 PM
macho17's Avatar
well i changed the spark plugs and i feel like a dumb *** for not remembering to do that when i did my last oil change, so i puttering is prolly good now but idk for sure because the boost is out right now and i cant get it to come back. After i changed the spark plugs and didnt get boost i unhooked the batter to maybe get some kind of reset but still no luck with the boost. Ne more ideas??..........one more little side note, before the boost went out today when i made a hard pull my dipstick shot out under the hood a shot alot of oil, dont know if that was jus coincidence or related some way.
