new clutch - grinding when turning
Old Dec 6, 2007 | 09:20 PM
cyberninja's Avatar
Just got a new clutch installed today from trusted mech's. Clutch looks like its holding up fine. (Normally chatter and whines as usual). When I try to make a left r rght turn, I start to hear grinding coming from the driverside wheel weld. I thought it was my brakes going bad because I also felt the brake pedal feel real weak. So I took a look at the brake pads and here they are below. Has anyone experienced this after an install?
Old Dec 6, 2007 | 09:21 PM
Ivan@AMS's Avatar
Brake dust shield rubbing on your rotor.
Old Dec 6, 2007 | 09:23 PM
cyberninja's Avatar
So you think the brake pads were fine? How do I tell where I need to pull or push the brake dust shield?
Old Dec 6, 2007 | 09:26 PM
cyberninja's Avatar
Oh.... and is this a common occurance when ppl installs a clutch?
Old Dec 6, 2007 | 09:27 PM
cyberninja's Avatar
bumpty bump?
Old Dec 6, 2007 | 09:37 PM
Ivan@AMS's Avatar
Yes its common when mechanics are not careful.
Test the shield for clearance first. Pull it towards the rotor and feel how close it is to the rotor. If its less than 1/8" you will need to bend it away from the rotor. Test the shield all the way around. Keep in mind as you bend one section of the shield, another section might get closer to the rotor. Keep working the shield till you have proper clearance.
Old Dec 6, 2007 | 09:49 PM
cyberninja's Avatar
Cool thanks. I just got back in from messing around with it. i pulled on end and the other bow'd out. I did not realize it can effect the actuall braking too.
Old Dec 6, 2007 | 10:09 PM
Ivan@AMS's Avatar
I did not read the entire first post. If you are having brake problems, there is another issue going on.
I would suggest you get your car back to your mechanic to see what was messed up.
Old Dec 6, 2007 | 10:37 PM
cyberninja's Avatar
I have pulled the brake shields a little here and there and it made the grinding almost go away. So they are definetly rubbing against the rotor. It figures because they will need to access the trans by removing the axel on the driverside and he probably pushed up on it. Im still going by there tomorrow though. Its completly dark right now and I would need to measure the distance from the shield to the rotor tomorrow. But so far it looks like that was really it.
Old Dec 6, 2007 | 10:38 PM
cyberninja's Avatar
btw the clutch is a fidanza kevlar clutch.
Old Dec 7, 2007 | 09:54 AM
ACTman's Avatar
There's the problem...
Just kidding!
Crester
20
Jan 12, 2014 10:42 AM
bdonIX
Dec 18, 2012 02:22 AM
ltn
42
Aug 19, 2012 05:51 PM
F0RSAKEN
Mar 1, 2011 01:22 AM
EvolNinja
Nov 26, 2007 05:15 PM
