dipstick coming out
Old Dec 8, 2007 | 07:37 PM
David Buschur's Avatar
The cause of the spring popping out is crankcase pressure. The rubber seal on the dipstick over time gets smaller and more brittle from the heat of the engine. When this happens it pops out easier and easier. Compounding the problem is the ring seal getting worse with mileage and generally higher boost pressures.
The spring fixes it, obviously we don't get rich selling them and CBRD doesn't get rich from o-rings.
The spring we make, should not fall off though as was said earlier. It is bent in such a way that when you put it on the dipstick bracket it should not fall off. I also can't understand having to use a set of pliers on it, it's not a brake spring and isn't really that stiff. Maybe my hands have just toughened from punching walls and my desk over the years! haha
Anyway, either will work but there's why it happens.
Old Dec 9, 2007 | 12:17 PM
CBRD's Avatar
come on dave, you know im funding my time attack car with o-ring sales LOL!!
I know your spring money goes directly into the black car lol
cb
Old Dec 9, 2007 | 12:21 PM
jhanksevo's Avatar
i sent a message to you chad about the o rings but never got a response back I was wondering where i could purchase them your site is down
Old Dec 9, 2007 | 12:26 PM
bluebyu36's Avatar
i would do a compression test this sarted happening to me when i fried my piston rings
Old Dec 9, 2007 | 12:27 PM
mdsevo06's Avatar
717-751-2345
Old Dec 9, 2007 | 12:36 PM
thebluesky's Avatar
Amazingly enough, you can make a very good knockoff of the Buschur spring kit at Home Depot, Lowes, or your local hardware store. But shhhhh...... don't tell anyone
Old Dec 9, 2007 | 12:39 PM
mdsevo06's Avatar
And at $3.59 a gallon, I can stay home and open the door for the UPS guy, with my $2.50 O-ring or $5.00 spring. Time is money and gas is not cheap.
Old Dec 9, 2007 | 12:46 PM
Cyloc's Avatar
I agree... the dipstick popping out is also a sign of blow-by. The compression test will make sure that your piston rings are still good.
Old Dec 9, 2007 | 06:41 PM
CBRD's Avatar
im sorry guys,
we have never been a "retail" company, and my follow up SUCKS!! but im trying!!
email me at chad@cbrdspeedfactory.com
cb
Old Dec 10, 2007 | 05:46 AM
C6C6CH3vo's Avatar
I don't understand how boost can cause this on a normally operating engine. Normal, I mean the following isn't happening:
  1. Pvc check valve sticking open
  2. blocked MAF pipe outlet on rocker cover
  3. blowby
Shouldn't sump pressure stay the same regardless of boost?
Old Dec 10, 2007 | 06:31 AM
crcain's Avatar
I could be wrong, but I want to say these are the reasons this can happen while nothing inherently is wrong:
a) more boost and more power = more cylinder pressure
b) longer stroke engines might disturb the crankcase more
c) forged engines made with looser tolerances than stock motors
d) o-ring on dipstick becomes loose over the years
Now I'm quite unsure about point A. In a perfectly setup stock motor... is there ANY blowby across the rings? I'd have to think there is _some_.
Old Dec 10, 2007 | 07:28 AM
rcheung's Avatar
The spring doesn't fall off. It just gets stuck at the bottom sometimes when I unhook it from the top and it gets away from me causing it to slingshot to the bottom . Thats all me though. The spring itself works fine.
Balrok
Apr 19, 2016 10:47 AM
Driv200
Jan 4, 2016 05:35 AM
johnnycage
11
Dec 10, 2012 07:46 AM
Jameson_IXMR
Feb 6, 2008 03:28 PM
dudical26
26
Jul 25, 2007 02:25 PM
