What would cause this??
Old Dec 9, 2007 | 08:36 AM
Buschur_TSI's Avatar
Ok let me start with a list of mods. Buschur 3" turbo back exhaust, hks 264 cams, walbro 255, manual boost controller, and a custom reflash. So I put some C16 in the car the other day and turned the boost up to about 28 psi. The car ran great pulled like a mother. Then last night it was much colder out and the boost was way over where it was the night before, so I started turning it down. I got it to about 26 psi and it will act like it is hitting fuel cut. Once you go over like 21-22 psi the car starts beaking up and just falls on it's face. It seems to be worse if you just hammer on it and not as bad if you kinda ease it to over 20 psi. Could it be blowing spark out?
Old Dec 9, 2007 | 08:40 AM
wizzo 8's Avatar
Seems like a posibility. How many miles on the plugs?
Old Dec 9, 2007 | 08:47 AM
sparky's Avatar
Are you monitoring AFR's?
Old Dec 9, 2007 | 08:49 AM
about 30k on the plugs and no I don'thave a way to monitor af I need to get my wideband in
Old Dec 9, 2007 | 09:02 AM
ExViTermini's Avatar
c16 is a leaded fuel. If you have 30k miles on your plugs your already pushing them for their application(really rich high boost 4cyl....). Sounds as though they have gotten lead fouled and are not functioning properly.
What is your gap set at?
I'd replace them with some BPR8ES gapped at .022-24.
Old Dec 9, 2007 | 09:06 AM
I will install new plugs tomorrow
Bigboost1320
12
Jun 22, 2015 03:44 AM
HFA_Ultima
May 30, 2011 01:32 PM
drewblueeye
Aug 30, 2007 07:33 AM
Steve@NoLimitmotors
48
Feb 13, 2007 07:02 AM
Warrtalon
72
Jan 24, 2006 04:50 AM
