More boost in the LOWER gears???
Like the title says for some weird reason I'm getting more boost in the lower gears than the higher ones. I have the ams gt35r kit which uses a 38mm external wastegate and I have it VTA. so how is this happening??? I always though boost creep came in the higher gears because of the increase in load. Ya think its just because my boost controller is a MBC which uses a spring and wont be exactly on target every time I boost???
Contact AMS, as they are the best qualified to give you a helpful answer. What boost level are you seeing in lower gears and what boost are you peaking to in top gear? What sort of BOV do you have?
I'm seeing like around 21.5 peak in 1st and in 3rd or 4th I see around 18 peak. and its the tial bov that ams sells
Are you sure you're not just getting confused with the taper effect? Whenever you're testing boost, are you baging straight 1st-5th? Or are you measuring in each gear independently? If you're going straight through 5th, then chances are you aren't going to see peak boost because you're already past peak torque in the rev range. It makes sense, but I'm not sure that this is your particular issue.
I agree. I'll probably data log 1st through 4th independently. and no I'm not sure its not just the taper effect. I don't have it tuned to taper down to a certain psi by redline or anything. does boost taper sometimes even if you dont have it tuned to do that???
barevolved
Oct 12, 2012 09:19 PM
orthojoe
40
May 11, 2010 07:40 AM
