Intake manifold weld problems
Old Dec 19, 2007 | 05:19 PM
Johnboy1065's Avatar
I have an aftermarket intake manifold and also an aftermarket FPR. Well I just got my engine all in and it running again and I noticed a certain tapping. But it was only happening around a certain rpm (3200 or so). I tried several things including looking at the exhaust to see if it was tapping any metal somewhere and didnt have any luck . well finally I found were it was making contact.
at a certain rpm my aftermarket intake manifold was tapping up against my FPR. well it has happened for a little while so at one of the Tig welds on the manifold it has been chipped away a little. BUT not completely. my question is do you think a local welder could kind of touch up that weld??? its in a reachable spot. I am worried about it because with race gas I run up to 32 lbs of boost.
Old Dec 19, 2007 | 06:02 PM
eclipsegsx012's Avatar
if you want to get it done right i would take the intake manifold off and bring it to shop.
Old Dec 19, 2007 | 08:08 PM
randomae's Avatar
to touch that up would take 10 mins. but you should def take it off for the welder
Old Dec 19, 2007 | 11:53 PM
these things are a Biatch to take off. I'll probably try and see what a welder thinks about the spot to get to. and if he can get his tool into that spot or not. also can most welders weld with aluminum??? I'm pretty sure thats what the Intake manifold is made of.
Old Dec 20, 2007 | 12:04 AM
Sharkbite2000's Avatar
You should be able too when I busted my pruven intake I got it repaired and no problems, even though I went with AMS VSR just to place it safe
Old Dec 20, 2007 | 12:06 AM
when you busted yours did you get any metal sucked into your engine???
Old Dec 20, 2007 | 12:23 AM
Nope because it was from inside out like a tank filled with air.
Green_Bandit
Lancer Aftermarket Forced Induction Tech
39
Sep 5, 2013 04:13 PM
evo4life94
Sep 10, 2012 07:41 AM
kimma
Dec 6, 2011 08:30 PM
EVO8LTW
10
Jan 22, 2009 03:42 AM
Noize
Feb 7, 2007 10:18 AM
