Does anyone get backfires from 2 step and exhaust?
Old Dec 20, 2007 | 07:10 AM
MitsuJDM's Avatar
I blow fireballs at rev limiter, if I let it rev that far or letting of the gas after being WOT for extended period of time. Having a Test pipe is usually what will cause this. Mostly any turbo car with a test pipe will do it, even N/A cars at times.
I was behind my friend with an N/A Integra GSR. He shot a little silent fireball once. He has a test pipe of course. Generally if you have a Cat this won't happen, because you cat is there to filter/burn up the gases before they exit into the atmosphere.
Old Dec 20, 2007 | 07:19 AM
Kerr's Avatar
Fomer Vendor
Don't think I get any fire, but mine sounds like this (I'm the wingless): http://s169.photobucket.com/MattDion.flv.
Old Dec 20, 2007 | 07:21 AM
bhamEVOguy's Avatar
Originally Posted by chu
What do you mean you dont think it has it anymore. What year is your car? I dont believe any 8 has them. I have an 8, and will ask for it when I get a tune.
u can do it urself. all u need is a tactrix cable, laptop and ecuflash. plus it all comes in handy later on to do the logs n stuff.
Old Dec 20, 2007 | 07:28 AM
Slomo Corey's Avatar
I've seen quite a few shot flames.
Old Dec 20, 2007 | 07:33 AM
Rally R's Avatar
2006 IX, it does have a reflash, just curious if that could have removed the limiter?
I have tried to find it while playing/practicing. RPM's keep rising??
Old Dec 20, 2007 | 07:38 AM
mdsevo06's Avatar
The 2-step was set higher then 5K, rev. it up to 6K and you'll find it.
Old Dec 20, 2007 | 07:46 AM
bhamEVOguy's Avatar
usually the tuner would set it to 5500rpms unless u ask otherwise
Old Dec 20, 2007 | 07:51 AM
Mr. Evo IX's Avatar
If you timing is retarded enough in the cells that the stationary rev limiter operates in, then the spark will fire while the exhaust valves are open and cause fireballs. Occaisonally I'll get a fireball but mostly it's at lift off and not related to ignition retard, just fuel.
Old Dec 20, 2007 | 07:53 AM
Pure Playaer's Avatar
mine doesnt
Old Dec 20, 2007 | 08:05 AM
chu's Avatar
chu
I am purchasing all that you mentioned. But I do not have enough know-how to do this myself. Although I will have a tuner do it, I'm reading and learning to make sure I understand his/her methods, so I am comfortable with the tune.
Old Dec 20, 2007 | 08:06 AM
chu's Avatar
chu
I think your 2step is probably raised and wasn't told so. Try reving up higher to find out where it's set at...and let us know if you backfire!!!
Old Dec 20, 2007 | 01:47 PM
LoCo4's Avatar
Did I see a 14 in that vid?
My car does it quite often.
Old Dec 20, 2007 | 01:59 PM
W_evo8's Avatar
05 8's have a 5k 2-step
Old Dec 20, 2007 | 06:01 PM
Kerr's Avatar
Fomer Vendor
Yeah, he missed a gear that run and let off.
Old Dec 21, 2007 | 12:30 AM
StlEvo05's Avatar
If you wanted to shoot fire *****, you could get the Bees rev limit. But I dont know why you would want to shoot flames unless you just wanted to set stuff on fire.
I pop and backfire on the decel, its kinda annoying.
