3 transfer cases in 3 months... help me!
Old Dec 20, 2007 | 01:05 PM
crcain's Avatar
Ok this thread may not apply too well to all of the USA members as I believe from the 7 onwards the transfer case is a bit beefier, as well as the front diff itself. However, I ask for your advice regardless because I need it!
Here is the story, I have a Evo 6, Magnus 2.4, HTA GT35R, Autronic SM4 tuned by Mark Shead, and a bunch of other bits. I'm real happy with the car on pump and on race its really very scary and so I love it.
Now the problem is, I keep breaking transfer cases. Here is some pics of the carnage and I'm hoping maybe someone can recommend something for me. Keep in mind the Evo 7/8/9 have different front diffs and transfer cases to the Evo 6.
All four busted transfer cases... one is not pictured as it is over to the left stuck to an old driveshaft! lol
Now here are two pics of the most recent failures... as you can see it is the same thing breaking:
And the other:
Before these two, I broke the output shaft from the gearbox:
And finally, the first transfer case failure I had was bit different. I had not that many mods yet, but had driven the car hard for like 4 years with lots of launches, and I guess it finally gave up. It was working but would click big time every 20 or 30 ft or so. Here is what it looked like:
The last one I think is not too important as it lasted me 4 years. The other 3 lasted me less then a couple months each.
Any help greatly appreciated.
At this point I'm concerned I can never run race fuel again!
Old Dec 20, 2007 | 01:07 PM
RoBear's Avatar
Dang! That's some serious carnage. I'm stumped, man. Someone on here will know how to help. Bump for an Evo bro
Old Dec 20, 2007 | 01:11 PM
EvoHung's Avatar
Look up Shep or TRE. They are the transmission/transfer case gods here in the States. Also, a while back i read about an Evo VI equipped with a JUN transfer case so you can probably check into that too. But damn! You must really drive your car.
Old Dec 20, 2007 | 01:14 PM
EvoHung's Avatar
Sheptrans.com, Teamrip.com. Look them up bro!
Old Dec 20, 2007 | 01:15 PM
Gusl's Avatar
For sure call Shep. He is the man.
Old Dec 20, 2007 | 01:18 PM
meckert's Avatar
May want to ask about cryo treatments and shotpeening...to see if you can't strengthen some of those weak areas..
Old Dec 20, 2007 | 01:19 PM
Silver06evo9mr's Avatar
i have a shep
Old Dec 20, 2007 | 01:22 PM
crcain's Avatar
I did call Shep... problem is not a lot of options for the six. I haven't sent him the pics yet so will do that now and see what he says.
I'm really jealous of you later evo owners as apparently you can get a Quaife front diff with LIFETIME WARRANTY!
Old Dec 20, 2007 | 01:31 PM
PhoenixEvo's Avatar
Holy carnage!!!! U have way too much power for what seems to be stock transfer cases . If this is the case u should really look into have a built TC.
Old Dec 20, 2007 | 01:33 PM
EnzoFerrari's Avatar
I have the fix for evo 4,5,6 transfer cases..
We had custom parts made for these cases.
We broke a ****load of them too on our EVO5.
Contact Jigga for details...
Old Dec 20, 2007 | 01:36 PM
Mr. Evo IX's Avatar
Maybe put a less aggressive clutch on the car. Also consider toning down your launch. My friend put a Exedy Twin HD in his 370whp Evo IX MR and got a broken hollow shaft just like you've got there, along with a broken center diff, and broken ring gear.
Old Dec 20, 2007 | 01:41 PM
Mr. Evo IX's Avatar
Did you all redesign the hollow shaft or the center diff gears?
Old Dec 20, 2007 | 01:44 PM
DS-03evo's Avatar
Take a layer off son!!
Old Dec 20, 2007 | 01:55 PM
jmartinez1170's Avatar
Thats easy
http://www.nolimitmotorsport.com/prod/QDH11B
If you crack this one you will get a replacement right away from the company. The give it a lifetime war.
Old Dec 20, 2007 | 01:57 PM
crcain's Avatar
mr jigga is pm'd
