Help please problem with A/C lines
Old Dec 21, 2007 | 04:32 PM
Bom's Evo's Avatar
I was about to go out tonight and heard buzzing sounds coming from the engines a/c area. So I pulled back into the garage and take a look.
The small metal a/c lines are burning hot, and the big thick hosed line is freezing.
The small ones run along the fender and shock tower. The thick hosed one runs by the cam gears/timing belt cover.
My friend blew up his a/c condenser a while back and freon was everywhere. I don't want to go anywhere till this is fix.
Whats the problem?? Can anyone help me? Thank you so much.
Old Dec 21, 2007 | 04:36 PM
Bom's Evo's Avatar
i hope i just need to recharge it.....
Old Dec 21, 2007 | 05:13 PM
KcEvil8's Avatar
that normal. the thick line are the low pressure side of the a/c system. it should be cold when the a/c is on and the thin line are the high pressure side of the a/c system and it should be hot.
Old Dec 22, 2007 | 05:33 AM
Bom's Evo's Avatar
For real? I didn't even have it on all season. And theres some kinda buzzing sound too. Must be something else then....ARGH!
Old Dec 22, 2007 | 02:21 PM
Bom's Evo's Avatar
okay found the problem.
It is the connector plug to the a/c compressor. I disconnected it and the wire came off. How do I fix this??
Is there some kinda resistor or something??
Can i just splice in new wire? or what? please inform me.
