Valvesprings and Cosworth Mivec Cams
Old Dec 26, 2007 | 09:23 AM
mcwop23's Avatar
Do I need to upgrade the springs/retainers if I just want to rev 8K for going through the traps? And if so whose kit should I go with?
Old Dec 26, 2007 | 10:23 AM
modena4re's Avatar
I opted to not go for the springs simply to conserve cash and set my rev limiter to 7500, but if you are only going to be going to 8k once every now and then while dragging, it will probably be ok and not hurt the motor. But if you plan on doing multiple runs all day long, I would upgrade for the peace of mind
Old Dec 26, 2007 | 12:45 PM
chaotichoax's Avatar
it is not necessary...keep in mind this is with your rev limiter no higher than 7,600
if you have the car tuned and increase the limiter than yes it'd be a wise choice to upgrade your valvetrain
Old Dec 26, 2007 | 12:59 PM
EVO316's Avatar
if you are going to be revin to 8k, just go ahead and upgrade the valvetrain.
Old Dec 26, 2007 | 01:10 PM
Chris@nolimitmotors's Avatar
+1
Old Dec 26, 2007 | 09:53 PM
mcwop23's Avatar
thanks for the input guys
Old Dec 27, 2007 | 01:24 AM
vboy425's Avatar
like everyone said. no need and by the way cosworth valvesprings/retainers are overprice and suck ***.
Old Dec 27, 2007 | 01:50 AM
krazirob's Avatar
cosworth is the HEAT!!!! second choice would be GSC
Old Dec 27, 2007 | 02:27 AM
vboy425's Avatar
Cosworth IX cams are good, if you want valvesprings and retainer get supertech
Old Dec 27, 2007 | 05:14 AM
StevenStarke's Avatar
Cosworth cams (unlike HKS) have a higher lift then stock cams so the spring will have to compress much more. The actual lobe on the camshaft basically sticks out more so it will compress the spring more. I always suggest customers should replace the valvetrain regardless of rev limit on a set of cams with higher lift. I mean obviously everything on evos is made to handle more then it comes with but its a good idea to get it done while your in there. Below is a picture and GIF of how it works basically. ITS NOT AN EVO HEAD THOUGH, BUT SAME CONCEPT. Imagine those lobes being larger or sticking off of the cam more. They would compress the spring more at all rpms.
Old Dec 27, 2007 | 07:18 AM
mcwop23's Avatar
I was thinking of upgrading to the buschur set.
Old Dec 27, 2007 | 01:59 PM
BURNALL_4's Avatar
thats what i got....PS: They're Supertechs
Old Dec 27, 2007 | 09:07 PM
mcwop23's Avatar
Appreciate the info
Old Dec 28, 2007 | 03:31 AM
krazirob's Avatar
nice pics there.........i guess valves it is then.......
Old Dec 28, 2007 | 04:16 AM
MR Turco's Avatar
does anyone have recommendations for NON titanium retainers (supertech was mentioned but i thought they were titanium). I know over time titanium retainers can gall and need to be replaced somewhat often. I would be willing to sacrifice a little weight for longevity.
