power steering fluid
Old Dec 27, 2007 | 11:43 PM
amscrazy's Avatar
well im going to make a long story short..i picked up my car and it had no power steering...turns out there is no fluid...is there anything special i have to do when putting new power steering fluid in?
Old Dec 28, 2007 | 08:43 AM
amscrazy's Avatar
bump
Old Dec 28, 2007 | 09:08 AM
mievoIX's Avatar
Nothing special. Make sure you check that there is no leak anywhere then just fill it up a bit at a time. Turn the steering wheel left to right then check and add if necessary, repeat until the level is good.
Oh yeah forgot to mention, make sure you crank the engine before turning the steering wheel. lol.
Or do what he says!
--- vvvvvvvvvvvv---
Old Dec 28, 2007 | 09:14 AM
rcheung's Avatar
To properly bleed the system.
1.Raise Front Wheels off ground and use Jack stands.
2. Disconnect Cam Angle Sensor
3. After you've topped it off, crank the engine while turning the wheel full lock to lock to bleed out any air.
4. Repeat until level no longer going down to confirm there is no more air in the system.
5. Reconnect Cam Angle Sensor.
6. Make sure car starts like normal
7. Clear CEL due to CAS being disconncted after car is able to started. (Optional)
Old Jan 1, 2008 | 12:42 AM
amscrazy's Avatar
so what would happen if i just put in the power steering fluid and turned the wheel while cranking the engine? do i have to disconnect the CAS and all that? bump
Old Jan 1, 2008 | 06:29 PM
rcheung's Avatar
It takes less than 30 seconds to remove the sensor and its so easy to get to. Its near the right side of the valve cover where the O2 sensor harness is. If you dont disconnect it you can flood the engine because as you crank the engine, it will keep dumping fuel in the engine.
Old Jan 1, 2008 | 07:45 PM
amscrazy's Avatar
so by "3. After you've topped it off, crank the engine while turning the wheel full lock to lock to bleed out any air" you mean turn the key with foot on the clutch and after the car turns over keep holding the key in the crank postition or what do you mean by number 3 by "crank" cuz after a certain amount of cranks the car turns on
Old Jan 1, 2008 | 07:55 PM
rcheung's Avatar
keep it cranking, if you remove the CAS the car will never start but keep cranking.
Old Jan 1, 2008 | 09:03 PM
BBS's Avatar
BBS
You should first worry about why there was no fluid. The fluid has nowhere to go and it doesnt just burn off. Fill it up, then check for leaks. Reservoir, pump, inlet pressure and or relief line, pump, seals may all leak.
Old Jan 1, 2008 | 09:09 PM
amscrazy's Avatar
no my pump was broken so i had one put in and it just didnt get filled up
Old Jan 1, 2008 | 09:10 PM
amscrazy's Avatar
and what do you mean by clear the check engine light...will it stay on if you remove and put back in the CAS
Old Jan 1, 2008 | 09:28 PM
cfdfireman1's Avatar
Just start it, fill it, turn it, top it off, you're done. What's the big deal?
Old Jan 1, 2008 | 10:16 PM
BBS's Avatar
BBS
lol. The whole CAS removal is up to you. Running the pump 2 seconds with no fluid wont burn out the darn thing.
Old Jan 1, 2008 | 10:20 PM
KcEvil8's Avatar
like he said but make sure you fill it up before you start it. no need to make things overly complicated.
Old Jan 2, 2008 | 06:01 AM
rcheung's Avatar
Yes you will get a cel when you put the cas back on since you tried starting it wihout it connected.
