wastegate adjustment
Old Dec 30, 2007 | 09:56 AM
20Grockit's Avatar
hey guys i just got a forge adjustable actuator to put on my green. i bought it used and it didnt come with any instructions. i looked on here but couldnt find any threads on how to adjust it. any of you guys help me out??? thanks.
Old Dec 30, 2007 | 10:41 AM
sparky's Avatar
Have you already installed it?
Old Dec 30, 2007 | 10:58 AM
sparky's Avatar
Once you've installed the WGA onto the compresssor housing via the 2 mounting bracket bolts, then loosen the backup nut located behind the turnbuckle(eyelet) on the end of the threaded actuator rod. Rotate the turnbuckle until the eyelet freely slides on and off the peg on the wastegate puck's pivot arm. Now give the turnbuckle three full 360* rotations clockwise effectively shortening the overall length of the actuator rod. Reinstall the actuator rod onto the pivot arm by slipping the eyelet over the pin and retighten the backup nut and install the cotter pin.
Old Dec 30, 2007 | 11:16 AM
20Grockit's Avatar
the eyelet is female and the actuator rod is male. both are threaded. it cant slide freely.
this is what the actuator looks like. it must be different from the fp. i wish i had my cam so i could take a pic of the eyelet and nut.
Old Dec 30, 2007 | 11:17 AM
20Grockit's Avatar
oh and no i have not installed it yet. im plannin on installin it this week tho
Old Dec 30, 2007 | 05:26 PM
20Grockit's Avatar
come on i know theres alot of guys on here with these actuators and no one knows how to adjust it. help me out fellas
Old Dec 30, 2007 | 06:36 PM
Evotech8's Avatar
As "sparky" said, you need to TURN/ROTATE the turnbuckle eyelet on the rod end to adjust it (shorten/lengthen). It does not slide.
Old Dec 30, 2007 | 07:36 PM
20Grockit's Avatar
ok so which does what? shortening tensions the spring and lengthening relieves tension?
Old Dec 30, 2007 | 11:02 PM
sparky's Avatar
Yes, shortening increases tension(preload). It keeps the flapper valve on its seat longer. Thus exhaust gas flow stays channeled within the turbine housing acting upon the turbine blades and improving turrbine wheel speed.
Lengthening the actuator rod allows the flapper valve to lift earlier, venting exhaust gas flow out through the turbine housing's wastegate bypass port. This bleeding off of exhaust gas flow causes the turbine wheel to slowdown.
Old Dec 31, 2007 | 02:29 PM
20Grockit's Avatar
how much boost is the the actuator good for and how do i tell when its adjusted correctly. i have my boost set at 23 psi on a stock turbo.
Old Dec 31, 2007 | 04:49 PM
cfdfireman1's Avatar
This otta do it.
http://store.forcedperformance.net/m...td-setting.mpg
Old Dec 31, 2007 | 05:03 PM
20Grockit's Avatar
thanks man i appreciate it.
Old Dec 31, 2007 | 05:10 PM
06EVOIX SE's Avatar
just because you saw it in a vid, you are going to believe it.........lol i'm just kidding thats the right way.
Old Jan 1, 2008 | 11:15 AM
20Grockit's Avatar
haha well its pictorial. by the way nice avatar.
Old Jan 1, 2008 | 11:21 AM
06EVOIX SE's Avatar
yeah thats my girlfriend (only in my dreams )
