Boost Control with tune
Old Jan 1, 2008 | 02:55 PM
EgoBstr's Avatar
I have made some minor modifications to my car and will have it dynotuned later this week. I plan to have it tuned once and leave it at that setting for the remainder of the time I own the car. Do I need to buy a mbc, or can I just have the boost changed in the tune?
Old Jan 1, 2008 | 03:22 PM
chaotichoax's Avatar
depends on how you want to do it
for simplicities sake you can modify the stock boost lines (drill brass pill out) and this will allow you to dial up the boost higher
advantage of a mbc is less taper and adjustability without the need of a lap top
I have a hallman pro mbc and I can't complain
Old Jan 1, 2008 | 03:41 PM
krazirob's Avatar
^^ yep yep.........you can adjust the boost a little bit with the tune but the possibilities are endless with a good MBC
Old Jan 1, 2008 | 04:24 PM
PHDoc19's Avatar
...well... up to the limits of the turbo.
Old Jan 1, 2008 | 06:19 PM
krazirob's Avatar
yes indeed........lol
Old Jan 2, 2008 | 10:12 AM
felickz's Avatar
Have you looked into ECU controlled boost with ECU flash??? My car is setup that way, and if you are into laptop tuning all of the software is FREEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE.
