How much lag on this turbo??
Old Jan 2, 2008 | 02:15 PM
dsm25psi's Avatar
SC6152E with .82 hot side how much lag will i have and what rpms should i see full boost around?
Old Jan 2, 2008 | 02:17 PM
StevenStarke's Avatar
2.0 or 2.3? should see 22 psi around 4800-5200 if its a 2.0.
Old Jan 2, 2008 | 02:25 PM
dsm25psi's Avatar
2.0
how much difference between 63. and 82 hot side
Old Jan 2, 2008 | 02:32 PM
mrdevo's Avatar
I believe a buddy of mine had this on his car. It didn't start pulling until almost 6000rpms. Maybe it was just his car but he did say it took forever to start pulling. I would just get a 35r if you are looking at this turbo.
Old Jan 2, 2008 | 02:34 PM
dsm25psi's Avatar
its almost $450 more for the gt35 turbo
Old Jan 2, 2008 | 02:37 PM
Goodi32's Avatar
They are both the same turbo
Old Jan 2, 2008 | 02:49 PM
kaonashi's Avatar
Dont get the E version get RE its ball bearing and itall help on the spool
Old Jan 2, 2008 | 02:50 PM
dsm25psi's Avatar
so i should see full boost at 5000rpms??
Old Jan 2, 2008 | 02:58 PM
kaonashi's Avatar
I'd stick with the .63 a/r unless your going to be on racegas/meth the whole time no need for it that big.
Its exsactly same specs as the GT35r but the GT series are oil/water cooled where the SC series is just oil cooled.
both have ball bearing options, and id stick with the .63 trust me and you should see spool around 4800ish
Old Jan 2, 2008 | 03:07 PM
dsm25psi's Avatar
Well i only got a special deal on the 82 hot side witch i could not pass it.
Old Jan 2, 2008 | 03:11 PM
dsm25psi's Avatar
The deal was so good i dont even know how the vendor make money on it.
Old Jan 2, 2008 | 03:12 PM
kaonashi's Avatar
how much did you get it for? The place i get my turbo's from is 1070$
Old Jan 2, 2008 | 03:15 PM
dsm25psi's Avatar
wow about little over 350 cheaper then that
Old Jan 2, 2008 | 03:17 PM
kaonashi's Avatar
OOOOOOOOOOOh thats because its the none ball bearing its journal dont waste your time.
795 New
Old Jan 2, 2008 | 03:18 PM
dsm25psi's Avatar
you can get a BB sc61 for 1070??? where??
